Home > Wanted > X-pin diff and 1275 verto diaphragm/spring late
longy
Member #: 2727
Bicester
Afternoon all,
I'm after a cross pin diff and a 1275 verto clutch spring plate/ diaphragm
Chris
1972 998 TURBO SLEEPER
stefaz
Member #: 1656
stoke-on-trent
I've got an x pin diff but its currently in a gearbox. i'll strip it out for you if you want
longy
Member #: 2727
Bicester
Thanks Stefaz, how much would you want for it?
stefaz
Member #: 1656
stoke-on-trent
£100 posted any good to you? it spins nice and free but I didn't build it so might be worth checking
longy
Member #: 2727
Bicester
how many miles has it covered?
stefaz
Member #: 1656
stoke-on-trent
About 1000 but it was in a 1275 na. Its not worked hard as far as I can tell. I just know what I'm like with bits. Strip them and check them anyway. I'll grab it out one evening this week if I'm at home
longy
Member #: 2727
Bicester
Ok cheers I'll take it , once you've wiped it out give me a shout and I'll transfer the funds Cheers
stefaz
Member #: 1656
stoke-on-trent
No worries. Will do
stefaz
Member #: 1656
stoke-on-trent
Have got the diff out of the gearbox now mate. Just gotta remove the crownwheel. Have some pics for you as well if you want them
longy
Member #: 2727
Bicester
That's great cheers, send over your PayPal details and I'll send over the funds cheers
I've got a NOS boxed 3 part Unipart GCK151 clutch kit Chris?
It's a Valeo cover & sprung plate and has the release bearing.
Wants a clean-up but if you want it, yours for £40 posted.
longy
Member #: 2727
Bicester
Cheers john, but only after the spring plate to build an RTS
