| Home > Non-Mini Discussion > l200 getting slow | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
5th Feb, 2015 at 06:45:54pm
Hi.
Edited by Rammie2000 on 5th Feb, 2015. you can do anything if you set your mind to it...
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
5th Feb, 2015 at 06:54:00pm
Id wager a turbo problem ( wastegate stuck open or something ? ).
5th Feb, 2015 at 06:56:34pm
Dont think so cause i could push it by hand. Hm can i test that? you can do anything if you set your mind to it...
5th Feb, 2015 at 07:39:59pm
Rammie Blow your tyres up. ...lol and change the oil and filter and airfilter and the fuel filter is my bet.
5th Feb, 2015 at 07:55:02pm
L200's are bloody slow anyway in my experience! Check brakes are not binding, it's common on the Shoguns don't know if the L200 brakes are the same.
5th Feb, 2015 at 08:03:46pm
Tyres are blown for economics... ( 3.6bars) oil should have been changed in the garage last month. Don't know about other filters though.
5th Feb, 2015 at 08:45:50pm
Split boost hose? On 7th Oct, 2010 5haneJ said:
![]() 263 Posts Member #: 8923 Senior Member North Wales |
5th Feb, 2015 at 10:25:00pm
My 2000 l200 was very sluggish when i looked N/S/F brake caliper was seized replaced that and front discs and pads...goes 10 times better now.
5th Feb, 2015 at 11:19:00pm
many excellent replies there rammie ............ keep us posted buddy
6th Feb, 2015 at 05:44:30am
Ill have a look at it in the weekend if possible . And for tom fenton. Yes they are slow. Been googlin the past night and should have said underpowered? you can do anything if you set your mind to it...
144 Posts Member #: 10557 Advanced Member |
6th Feb, 2015 at 02:24:02pm
Seems to recall EGR'S on those can stick....dependant on age of vehicle in question though.
Double-Blind experiment, N:
6th Feb, 2015 at 04:46:00pm
Okey. So as a prospectus i rang the garage. Filter was replaced 20 k ago so he says cant be that. Asked him about split hose or so same answer... then he asked are youa mecanic? Sayd no. Then hesaid then how do you know what you talk about. If there wor any problems it should show on the ecu as a fault reading. .. and besides why would you want to drive more then 80 kmh with a trailer??? Wtf!! It soaked up like 40 litres on 100 km to go 80 with a trailer and he finds that normal? Told him ill pick up the trailer come to the garage and let him test drive it. Then get my mini with the same trailer and but merely 40 hp instead of 120 hp and check the difference. .. if he dares to give me an answer like that then i swear to f... god ill run him over.
6th Feb, 2015 at 05:01:57pm
Just relax and take your car somewhere else. I have to say though i find l200 s to be slow as hell lol. Turbo or turbo controll is another place to look, if its vnt and vacuum controlled an airleak in the vacuum line will stop you making boost or limit you quite a bit. turbo 16v k-series 11.9@118.9 :)
6th Feb, 2015 at 05:11:16pm
As Denis says take it elsewhere. I have a Shogun 3.2 and it tows brilliantly, 170bhp/275ftlb but the L200's get the 2.5 engine at 115bhp/175ftlb and it isn't great.
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
6th Feb, 2015 at 10:18:02pm
Ive driven toms and it certainly shows its bigger power output like our old mk2 shogii?? 3ltr petrol and its predecessor a 2.8 diesel, whilst our challenger/l200/shogun sport is slow it will easily pull the hoss box with 2 hosses in at the legal limit, mainly cos it has fucking ridiculous gearing, meaning that any motorway work leaves me pining for the old shogie, my remedy is to just use the van instead lol. I mean they were made to fill a gap when the shogun became too expensive and high spec, so the sport is there answer to the 200 tdi defender basically, near as damit same engine output but I couldn't get a decent landie for twice what that cost me, plus it does have some marginal comforts which being Japanese still work even though its 300 years old
Edited by oli79 on 6th Feb, 2015. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
7th Feb, 2015 at 07:49:57am
My main problem with changing over garage is that its the only one miles around. Can i blanck of those egr valves my selves? And second up. Is it possible that it has one of those problems without chowing on the computer system of the car.... its freezing outside and my friends goat ( 2cv) is preventing me of driving it inside but wil try and check the boost pipes and so on from close by today. It did indeed feel like what my van had some time ago ( and that was stuck egr valves it just had a dul flat powercurve and the higher the reves the duller it felt... got that one chipped to bypas the valves because they were computer operated instead of vacuum) you can do anything if you set your mind to it...
11th Feb, 2015 at 07:35:51am
Gave it some time yesterday. Found that the clamp arround the bothem of the boostpipe was gone. Fittet one of those metal screw on things. Did not yet test it with a big load. Now i did some googlin in between and seen there are diesel addetiefs to clean turbos..... bardholl selles such stuf. You recon it would be worth a try to be on the safe side? you can do anything if you set your mind to it...
