Home > Beginners Tech > Fuel regulator question
flyingturd
Member #: 4008
near cardiff np12
Ive got a few bits left on my mini before i take it to be set up properly, I believe my mini is running rich as it have black smoke coming from it when reved.
is this down to the fuel reg? how to you set how much fuel it needs thanks
thanks
fixitphil2
Member #: 10945
scarborough/ northyorkshire
You need a fuel gauge there only about a £10 on eBay, then set fuel pressure to 4 psi. Adjust main jet in carb so that it's flush with the top of carb then 2 1/2 turns down that's the base setting
It's unlikely the FPR is the problem, but fuel pressure should be checked so you know it is correct anyway.
flyingturd
Member #: 4008
near cardiff np12
cheers any recommendations on what one to buy as there bare loads on the bay
flyingturd
Member #: 4008
near cardiff np12
I bought a pressure gauge what should i be running?
steve1275
Member #: 951
Bromsgrove
I aim for 4-5 psi on no boost
'Where does the engine go?'
flyingturd
Member #: 4008
near cardiff np12
im running standard boost 4psi? The gauge is showing on tick over, still showing black smoke
Fuel pressure will have no effect on the car at tickover, unless:
1) It's too high and all you do is flood the engine and the car stops.
2) it's too low and it can't open the needle valve - result, the car stops.
As it's a HIF I bet the choke seals are buggered. No point taking it to the RR if you've not checked and changed them.
Finally, have you tried leaning the mixture? and where is the jet currently sitting?
flyingturd
Member #: 4008
near cardiff np12
ok thanks for the advise ill take a look.
cheers
flyingturd
Member #: 4008
near cardiff np12
would i have to buy a full rebulid kit?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i bought a genuine SU kit and just went over the whole carb do cheek out the passage ways thouauly it apiars i missed the bowl vent to plenum ones and have had to use the well known "T piece trick"
no expert but i think the jet should be just below flush with the bridge take the dash pot off to check that just 3 screws
as wil h said check the choke out but if its gone bad imo might as well do the whole lot ie a full kit at least youll have a good change of no problems
flyingturd
Member #: 4008
near cardiff np12
which kit do i buy any links
metroturbo
Member #: 989
North Yorkshire
Have you checked and set the idle mixture?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
where i got mine from
http://sucarb.co.uk/rebuild-kit-for-hif44-...etro-turbo.html
its got all the raplacemet screws for those crap tamper prof ones if yours has them also had spindle bushings and shaft throtle place seals gaskets i was inpressed witht he kit and how it went in for me just my opinion
Edited by Turbo This.. on 26th Feb, 2015.
Turbo-phill has the full rebuold kits. Be careful of the ebay 'service' kits. These don't have all the parts.
flyingturd
Member #: 4008
near cardiff np12
which screw is this?
ive order a kit for the carb
