| Home > General Chat > O/T - Bini question | |||||||
16th Feb, 2015 at 02:31:04pm
OK, wrong forum but I know a few of you have them as a "second car".
16th Feb, 2015 at 02:46:17pm
No. At least 10mm or possibly even more new.
16th Feb, 2015 at 02:47:21pm
PS
16th Feb, 2015 at 03:00:31pm
from what your saying, it looks like sweet FA has been done. Company Car or not, I'd be asking some polite questions from the service team.
16th Feb, 2015 at 03:43:22pm
Thanks both,
54 Posts Member #: 10130 Advanced Member Was Netherlands, now Philippines |
16th Feb, 2015 at 03:57:01pm
Yep, they have wear sensors on it. If they are worn, the brake warning light will burn.
16th Feb, 2015 at 08:32:35pm
On 16th Feb, 2015 miniturboRene said:
Yep, they have wear sensors on it. If they are worn, the brake warning light will burn. If they are plugged in of course.... If there is only 3mm, then it's already past the sensors. I suspect all they did was unplug them, and re-set the light (i assume the light is why it needed them)? On 17th Nov, 2014 Tom Fenton said:
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
16th Feb, 2015 at 08:33:31pm
Give them a little visit n confront them... see how they react On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
![]() 328 Posts Member #: 9107 Senior Member Devon |
16th Feb, 2015 at 08:52:24pm
I bought a 58 plate one for my wife with 22k on the clock and it clearly never had the oil changed despite having 4 stamps in the book. Took it back and they "changed it for free ". Funny enough when I checked it again the oil was black and stunk , looked at the sump plug and it hadn't been touched . Complained got no where so did it myself . In short I have heard nothing but bad things about their customer service and workshops .
16th Feb, 2015 at 08:56:38pm
I would be playing merry hell at volume in person at the dealership. Brakes are safety. They obviously don't value your wife's safety. On 11th Feb, 2015 robert said:
16th Feb, 2015 at 09:40:41pm
Bmw seems to be giving crap service out at the moment seen a few people moaning |
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
17th Feb, 2015 at 10:48:03am
Send them a letter (to the dealer and the BMW head office and the lease company if it is a company car) to formally let them know they did a service not according to bmw standards and you will pursue this legally.
Edited by Sir Yun on 17th Feb, 2015. That sir, is not rust, it is the progressive mass reduction system
17th Feb, 2015 at 01:12:22pm
The wear sensors are fitted to front and rear, but unplugging them will not turn off the light, in actual fact to turn off the light you need to plug in a diagnostic box to reset even after you have replaced the pads and wear sensor for new.
18th Feb, 2015 at 02:08:36am
I reset the light in our r55 without a computer... You just use the stalk button. Very easy to do. My pads are also unplugged, as it annoys me to change out pads that are just under half worn lol... I can easily check them through the cavernous gaps in the factory wheels, so no biggie... Edited by turbodave16v on 18th Feb, 2015. On 17th Nov, 2014 Tom Fenton said:
18th Feb, 2015 at 06:54:41am
on that both r53 and R56 brakes I've done for brake pads wear sensors I replace them plug it into the brake pad then the wiring loom Start the car and it does off after driving a few feet down the road same as doing the abs sensors.
On 17th Feb, 2015 Tom Fenton said:
The wear sensors are fitted to front and rear, but unplugging them will not turn off the light, in actual fact to turn off the light you need to plug in a diagnostic box to reset even after you have replaced the pads and wear sensor for new. |
18th Feb, 2015 at 07:28:14am
Well I must be fucking lying about the car parked outside then....FFS
18th Feb, 2015 at 08:37:17am
On 16th Feb, 2015 apbellamy said:
I would be playing merry hell at volume in person at the dealership. Brakes are safety. They obviously don't value your wife's safety. this would be me too dont need a computer with my dads R53 either ( except for abs light ) Edited by Brett on 18th Feb, 2015. Yes i moved to the darkside |
18th Feb, 2015 at 10:33:34am
R52 doesn't need anything to clear the ABS light.
In the 13's at last!.. Just |
18th Feb, 2015 at 05:20:30pm
Air bag light will go off if you stick a 3.9ohm resister in it. If it's the air bag in the seat. Just disconnect the battery for 5 mins job done
18th Feb, 2015 at 10:34:31pm
On 18th Feb, 2015 Tom Fenton said:
Well I must be fucking lying about the car parked outside then....FFS This is how I re-set the brake pad warning light after changing the pads on the R55, which like yours, is also parked outside LOL. The mini gets the garage, the bini gets wet. http://youtu.be/aKnLvitsXzs http://youtu.be/5FwJz2KSD4M On 17th Nov, 2014 Tom Fenton said:
18th Feb, 2015 at 11:07:33pm
On 18th Feb, 2015 theoneeyedlizard said:
R52 doesn't need anything to clear the ABS light. I swapped a faulty sensor out on ours last night, light stayed on until I drove it. It's now cleared itself. Airbag and service lights are another matter. Thats the one, on my dads its the passenger seat belt that sets it off, its the only seat that gets moved for the rear passengers and the wire gets pulled then the light is on Edit : Actually thinking about it there is a button in the centre console for the abs light its the same one for low/un even front tyre pressures, i did 2 sensors with the wheel bearings, i think you hold the button while turning the ignition on or something Edit2: i may be talking bollox too a collapsed bearing had eaten the abs sensor when i got my hands on it all the lights were on Edited by Brett on 18th Feb, 2015. Yes i moved to the darkside |
