Home > Help Needed / General Tech Chat > another what to get for my engine question. shopping list has been made up. opinions appreciated.
Rammie2000
Member #: 10190
belgium
hi all
so as for now i finally can get up the next step of building my turbo engine. i am going to use the metro engine ( was a na engine) i have ( only 30000 ish km on the clock) ill have it skimmed and honed in a few weeks.
will the standard camshaft be good?
but next up is what to get?
new cranck bearings ( standard size)?
new cranck trustwachers? but which ones? std 1275 or +30 or...?
primary gear shims?
big ends?
greets and thanks for the help.
Edited by Rammie2000 on 8th Apr, 2015.
Rammie2000
Member #: 10190
belgium
and this to start with? http://www.ebay.co.uk/itm/CLASSIC-MINI-MET...=item339f082f41
slater
Member #: 1291
Suffolk / Birmingham
Standard cam will work but may not be ideal. A mild NA cam like a MG metro cam works quite well.
Your bearing sizes all depends on your engine. You have to measure and work out what you need.
Sounds like you have some learning to do!
Rammie2000
Member #: 10190
belgium
The engine is a mg metro engine and its the original cam so mg metro cam? And yes i have some learning to do. I have build some na engines but never on this level. ( i made it fit and they runned wel) but now i want it all to be perfect.( or as close to perfect that i can)
Rammie2000
Member #: 10190
belgium
http://www.amazon.co.uk/ULTIMATE-MINI-BUIL...S/dp/B002HRYFSM
is this a good guide dvd i seen it once but been years ago. and to be honest i have the memorization of an elephant with amnesia ( seriously i tattooed the birth date of my daughter on my arm to remember it)
i read a few good seperate things what to do on here but a step by step guide would be nice. ( i do have both hayness books resto manuel and another one cant remember... and the tuning the a series engine book of david vizzard to )
i am handy with engines ( hense my winning 250cc racer 2 stroke) and did build some na engines in the past but never a turbo engine... they just make me nervous.
greets
Yes very good dvd guide, that is all i used ( and TM searches) to teach my self how to do gearboxes
PhilR
Member #: 10034
Birmingham
Strip the engine and you'll be able to work out which bearings need replacing. Any research you do will make more sense when you have the parts in front of you, e.g. you'll know for sure which cam you have. At this point you'll have much more confidence, and learning will be easier.
A good starting point is always http://www.turbo-mini.com/. If you make a list of everything you don't understand, it's just a matter of searching and learning. Don't buy any parts until your 100% sure about your spec.
You can build your engine with very few (or none) of the Metro Turbo parts. Parts like the old distributor you linked to may work, but there are usually better options these days.
Edited by PhilR on 11th Mar, 2015.
Rammie2000
Member #: 10190
belgium
yeah just had a search on the cams.
both are crap ( they are in good nick but... ) i have the standard ( unmarked) cam and the one with the 2 rings between lobe 7 and 8 from a the 1275 sprite/injection cam
Rammie2000
Member #: 10190
belgium
and then i came across this. dirty as... but at least i found it back
thats the metro one right? as i can compare here on what i found and on ac dot his website
Edited by Rammie2000 on 11th Mar, 2015.
Rammie2000
Member #: 10190
belgium
1275grimsby
Member #: 10874
Grimsby
It has the 1/4" groove which is what I went by.
I got my info from here:
http://www.theminiforum.co.uk/forums/topic...identification/
mine: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=570945
Rammie2000
Member #: 10190
belgium
Owkey. So been looking for the dry deck thing on here but methods seem to be divided some use bras plugs others use normal steel bolts with the heads cut of and so on. I have no lath and live in a metric country where unf taps are rare and expensive. What would be thee best methode to go for here? Do the normal steel bolts work? What loctite? I seen some use regular superglue?
Rammie2000
Member #: 10190
belgium
Thanks.
My build thread page 6 has some pictures
Im not sure if the large holes in a 998 are the same size but it should be a starting point
On 27th May, 2010 Brett said:
the head was pluged with m8 grub screws and diy m16 grub screws
the block m8 grubs and diy m14 grubscrews all secured with 'property of mod' locktite :)
Edited by Brett on 18th Mar, 2015.
Rammie2000
Member #: 10190
belgium
Ill look for it.
so for the grub screws i have the choice between stainless steel and regular steel screws.
what would be best? the material of a mini engine has a expansion coefficient of 9.... the steel screw have a coefficient of 12 and the stainless steel screws have a coefficient of 16
i have seen that there are many types of materials used here but mostly brass witch has a coefficient of 18.4 but not the same hardness of course so can be pressed easier by the blok. what i am saying i guess is that i do realyse that ii need a material that expands well to make sure it closes up good but am afraid if use to hard of a material it will create cracks in the blok and head.
Edited by Rammie2000 on 18th Mar, 2015.
slater
Member #: 1291
Steel will be fine. It's not that critical. Just loctite them in.
Rammie2000
Member #: 10190
belgium
okey. im on to the next step. now what is the difference between those 2 cam bearings?
rest of my list is as following ( cranck that ill use will be a cam 6232)
(here again 3 choises)
http://www.minispares.com/product/Classic/....aspx|Back%20to
anything missing on my shopping list to rebuild the midblok?
