Home > Help Needed / General Tech Chat > 998 m45 pulley calculations
sam138
Member #: 10219
I have had a read through a few forums and seen that my supercharger kit which contains a vmax scart front pulley will need re sizing or a new sc pulley will be needed . Please could someone advise what size I need to run 7psi on 998cc m45 charger . Believe s/c pulley is 65mm standard not sure what size max front pulley is . Which one needs changing to get the right ratio ??
sam138
Member #: 10219
Any idea if I can run vmax pulley and standard m45 supercharger pulley 65mm on 998 cc ??
sam138
Member #: 10219
jonny f
Member #: 9894
Dorking
call vmax......
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
do a "snow mobile" pully setup full boost at idle and the ratio changes with rpms?
just a random idea.. !!
Chalkie
Member #: 9764
Northamptonshire.
Find out what Size pulleys Minis run with the m45 then check Sizes on yours Google how many rpm it boosts from and you should then be able to mathematical work it out
Or I'm chatting shit who knows bit worth a try eh?
