Home > Help Needed / General Tech Chat > Brise high torque starter motor problems?
mw3
Member #: 9590
Derby
Been having a fair few issues with trying to get my car started...
wouldnt turn over on the starter the starter pinion kept throwing out its one of these
http://www.demon-tweeks.co.uk/motorsport/a...e-starter-motor
went through my normal messing about of jump leads due to me thinking it was battery related etc
in the end out of desperation i fitted the boggo standard shagged starter motor out of my spares in the shed it cranked it over perfectly and started straight away.
so anyone else had these type of issues?
Matt W
On 14th Mar, 2012 mw3 said:
Never heard anything good about Birse starters.
Have a look at the Minispares ones, OEM quality.
send it back, I had problems with there most expensive axial solenoid starter , they fitted the wrong pinion, and it fucked the insides , they did repair it once i pointed this out .
I have the same starter on the don and its been fine
carl
Yes I get every now and then I put it down the fact I don't use it much, I found also I had to loosen the top bolt off and push the top of the starter away from the block as it would bind up.
Simon.
mw3
Member #: 9590
Derby
Cheers guys, spoke to deemon tweeks they said box it up and thell arrange collection and send it back to brise
Matt W
