| Home > Help Needed / General Tech Chat > Crunching into 2nd (again!!!) 24.08 - Still working. | |||||||
19th Mar, 2015 at 08:51:48pm
So
Edited by minimole23 on 24th Aug, 2015. On 7th Oct, 2010 5haneJ said:
19th Mar, 2015 at 09:38:47pm
Are you using a quick shift? |
19th Mar, 2015 at 09:46:32pm
No, just a home brew internal gear linkage. that has been the same for 3 years. Edited by minimole23 on 19th Mar, 2015. On 7th Oct, 2010 5haneJ said:
19th Mar, 2015 at 10:31:39pm
Mine knocked out 2nd straight away and ive not stripped it yet but i have a inkling i might have got the hub fitted backwards? If that is even possible! I remember they have a ring on one side so are not symmetrical but are not far off. Just wondering if you had checked? |
19th Mar, 2015 at 10:42:22pm
i would replace the syncrobe 2nd and third hub, and deffo replace the home brew internall gear linkage to a standard one ........... , my monies on thats the cause of all your troubles
![]() 684 Posts Member #: 9590 Post Whore Derby |
20th Mar, 2015 at 06:17:17am
I've had the same issues 18 months ago if you can remember...
Matt W
On 14th Mar, 2012 mw3 said:
Got a nice big delivery from Carl at Force Racing today. |
20th Mar, 2015 at 08:54:52am
Matt, he has already replaced the rings with good used ones though suggesting it could be something else (not saying its not down to bad luck on a second set of rings mind)
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
20th Mar, 2015 at 09:52:53am
Who made the gear set ?
Metric is for people who can't do fractions. |
20th Mar, 2015 at 07:43:42pm
Steve, The gear linkage is fine, plenty of uj's and 5 engine stedies so the engine isn't moving at all. It was fine for 3 years without knocking out 2 sets of rings in 500 miles. Also I have welded the hole up for the original!
21st Mar, 2015 at 09:15:09pm
So, a strip down reveals that the baulking on 2nd is shot again, worn to the gear face. Probably gonna want a new 2nd gear now too for good measure. 3rd baulkring is looking worn, but will confim with some other spares tomorrow. 1st and 4th again seem good.
21st Mar, 2015 at 09:27:47pm
I know from experience, you can't successfully fit the main shaft assembly into the box with either of the synchro hubs on the wrong way round. On 11th Feb, 2015 robert said:
109 Posts Member #: 10368 Advanced Member Australia |
22nd Mar, 2015 at 08:21:13am
are the dogs on the baulk rings still in good nick... there seemed to be some variable heat treatment on some a while ago... you could see much smaller heat treated area compared to a good one. This is a worrying trend.. Did you take a small amount off the back to help engagement? |
22nd Mar, 2015 at 08:30:29am
Wernt minispares testing some new superduper ones? I run a supercharger and I don't care the TB is on the wrong side.
22nd Mar, 2015 at 08:38:32am
Dragging clutch? Yes i moved to the darkside |
22nd Mar, 2015 at 07:16:25pm
ALWAYS check the dog teeth on the synchro hubs and gears. If these are worn, they need to be replaced. A good synchro rings will not rectify this.
22nd Mar, 2015 at 08:17:56pm
Vegard, how would worn dog teeth result in crunching, I could understand difficult engagement. I will admit the syncro teeth wern't perfect but more than usable, again had been fine until I changed the gears themselves.
23rd Mar, 2015 at 06:35:29am
It's not the first time I've seen gear cones like that. Don't know why it happens. I'd send it back to where you bought it. On 13th Jul, 2012 Ben H said:
23rd Mar, 2015 at 11:40:09am
From those photos it seems the cone on the gear itself is clearly the issue, not the baulk ring (unless there is something so bad about the baulk ring material or heat treatment that it has chewed up the cone).
23rd Mar, 2015 at 08:26:32pm
This is the olf second gear from the metro van.
24th Mar, 2015 at 07:36:57pm
Well thats bloody worrying for brand new gears, that were carefully, cleanly assembled, and run with good oil.
25th Mar, 2015 at 09:02:44am
On 24th Mar, 2015 minimole23 said:
Rod, the new baulkring I have lying round has good clearance, trouble is so did the ones that are now looking worn. Andy's one looks even worse. But with that kind of roughness on the cone I doubt a new baulk ring (or even a good used one) will last long before it's clearance has gone. The question is cause/effect - bad material and or heat treatment on the gear cone so it has worn rough and then just wipes out the baulk ring, or a bad batch of baulk rings that destroy an otherwise good cone. If your's and Andy's gears were from the same supplier then it's the more likely culprit. If you have any friends doing a mechanical qualification at a local tech college or uni they would have access to the materials lab which 99% is likely to have a hardness tester - a fairly crude test on the surface of the cone and the inner surface of the baulk ring would give some clues. Schrödinger's cat - so which one am I ??? |
25th Mar, 2015 at 09:31:57am
The gear Andy has shown was an old Minispeed one from an ST ratio gearset.
27th Mar, 2015 at 10:08:47pm
Returned 2nd and 3rd to the supplier, along with all damaged baulk rings, so will report back the verdect. Edited by minimole23 on 28th Mar, 2015. On 7th Oct, 2010 5haneJ said:
10th Apr, 2015 at 08:50:21pm
Well, very pleased with minispares customer service.
10th Apr, 2015 at 09:13:08pm
Good news. I always say the test of a supplier is when things go wrong. Clearly minispares appreciate customer service |
