| Home > Help Needed / General Tech Chat > Destroyed pot joint.... I'm absolutely stumped! | |||||||
283 Posts Member #: 8215 Senior Member Rayleigh |
29th Mar, 2015 at 10:31:56pm
Elo
Edited by Custard on 29th Mar, 2015. Dave the Cake |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
30th Mar, 2015 at 11:57:46am
Can this be due to different lengths of the driveshafts; switching sides/mix with other set?
Dazed and Confused.... |
30th Mar, 2015 at 01:10:45pm
I didn't think it was possible to get the drive shafts round the wrong way? They are the same as have been on the car for at least the 9 years I've owned it.
Dave the Cake |
30th Mar, 2015 at 01:13:45pm
You probably have the cage in backwards. Ive done it myself. It will drive until you get to a bump then the balls pop out. Turn the cage around and all is fixed. |
30th Mar, 2015 at 03:08:53pm
What slater says, when my aseries turbo was going to the track for the first time i blew both pot joints pulling up the ramp to the trailer i had previously driven it about but under no great load Yes i moved to the darkside |
30th Mar, 2015 at 03:17:09pm
As above except I think it's the inner bit of the joint, not the cage. The inner bit can be accidentally reversed and move the balls outwards.
30th Mar, 2015 at 06:01:49pm
Dave the Cake |
30th Mar, 2015 at 08:49:21pm
That cage looks the wrong way to me |
30th Mar, 2015 at 08:53:29pm
I think the cage can come off if you take the boot off and slide it down the shaft.
30th Mar, 2015 at 08:58:01pm
The cage is deffo on the wrong way, and I'm sure of you just rotate the cage a little it should just roll off On 26th Oct, 2004 TurboDave16v said:
30th Mar, 2015 at 09:06:28pm
Maybe I should stop playing with cars....fml
Edited by Custard on 31st Mar, 2015. Dave the Cake |
30th Mar, 2015 at 09:14:48pm
yep, the centre cant go the wrong way around iirc
31st Mar, 2015 at 10:54:23am
My bad, it's the cage wrong, not the inner part like I thought....
7th Apr, 2015 at 01:02:33pm
Also, remember that there are two sizes of Pots. On 13th Jul, 2012 Ben H said:
7th Apr, 2015 at 04:08:54pm
On 7th Apr, 2015 Vegard said:
Also, remember that there are two sizes of Pots. |
7th Apr, 2015 at 04:32:07pm
This is one if my mini related bug bears, on other joints on other cars you wouldn't dream of randomly mixing and matching inners outers cages etc, yet for most it's standard practise!
