Home > A-Series EFI / Injection > where to buy a mega squirt ecu
Hi Guys, any recommendations where and who is best to get a mega squirt Ecu ?
Many thanks Matt
Phil at Extra EFI ?
UK or abroad, or any specific application ?
Matt Cramer at DIYAutotune does a lot of pnp kits now although he's in the US
Or I think that Trigger Wheels seller in the UK does kits too
Edited by stevieturbo on 6th Apr, 2015.
Thanks Stevie I'll pass that good info on.
monsterob
Member #: 11029
Crewe
second that the kit car had one from phil
great service and aftersales
Outside the box
Cheers Monsterrob :)
After this last week, My advice is.... Dont bother unless you are set on Port EFI on a siamease port. But then who listens to me anyway *happy*
I was set on Megasquirt but now dont see the point, there is now just simply to much info out there imo fo a self build and setup, for me megasquirt has gone from a simple self build to a confusing mess.
Personally i think that buying a system in to learn ecu mapping is the best way, it also makes no sense to buy a megasquirt and then find a mapper you are far better off finding a good mapper and looking at what they map, i am sure you will get a better and cheaper product going this way.
I think that MegaSquirt is great if you are seriously interested in electronics and making it yourself. If you just want an ECU to run an engine so you can drive the car then there are probably more simple alternatives out there. Also as mentioned above rightly or wrongly many mappers are dubious of MegaSquirt or even will refuse to use it, whereas if you turn up with one of th big names in DIY built cars/amateur ECU's, Emerald, DTA, Omex, any mapper worth bothering with will have no problem.
