Home > Technical Chat > Swapping ports...
rich080487
Member #: 9306
Welwyn Garden City / Milton Keynes
Just putting it out there, but I have been thinking about charge/flow robbing in the standard head...
Has anyone ever considered using the current inlet port (siamesed) as exhaust ports, and using the 3 exhaust as inlets?
This would remove the inlet charge robbing as the inner cylinders would now be siamesed which is ok. It would require new camshaft, inlet & exhaust manifold, plus a completely different types of combustion chamber work.
Any thoughts, or am I being completely stupid...
Thanks, Rich
Valves for a start. 29mm inlets would be crap, with no way of fitting decent sized ones.
It has been done in the past I think they used to make the camshafts I read somewhere else?
probably easier to add 2 more intake ports
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
better n easier to k head it and make good power
It's an interesting idea. But so many reasons that you'll end up with more issues than you solve makes it a non starter for me.
It would just shift the problem to the exhaust port. Big pressure spike as the outer cylinder exhaust opens just as the inner cylinder exhaust is approaching overlap with the inlet.
Reverse flow into the inlet, poor scavenging and power reduction would result.
Just saying :)
rich080487
Member #: 9306
This is all I thought "interesting idea" wonder if it has been done before.
Just saying :)
OK. This is kind of opinion I was looking for, thanks.
I know there would be a lot of mechanical work to get it going, so I think it seems a bit much work for not much gain. Thanks for everyones input.
Time to start looking into different head options...
For the cost and development I would suggest a 7 port would be cheaper?
You can always accept that charge robbing occurs and take advantage of it :)
rich080487
Member #: 9306
That is another option. I just need to decide whether to stump up the cash for new one, like SC; or whether to wait around for a second hand one (although I haven't seen any yet)
Paul, interesting, by this do you mean turbo? Or something more fancy that I haven't thought of?
Cheers!
Just some theory/science that I've been working on.
jbelanger
Member #: 831
Montreal, Canada
Paul, is that about the intake/exhaust manifold length and camshaft timing you already simulated and posted? Or is there more to come?
http://www.jbperf.com/
It's continuously evolving *smiley*
Does it really matter? You can make 200bhp+ on a standard arrangement 5 port head. That's plenty for a mini.
Sir Yun
Member #: 1592
Smart Guy!
I did some sims on a reverse 7 port so siamese in but 4 exhaust ports. There is some decidedly odd stuff happening.
I just realised that the outer cylinders of a 5 porter runs at a BMEP of about 13.5 to 14 (that is what a well fettled K1200 head would do It would also produce more than 170 bhp for a 1380)
you just loose so much on the inner cylinders
and I'm now pretty sure that is due to the shared intakes as it does this with 3 and four exhaust ports
I'm finding that the 5 port A Series is limited by the size of the valve throat, due to the small bore/long stroke configuration for the engine capacity. The siamese port has an impact on maximum power output but, in my opinion, it is not significant. Generally what the inner cylinders lose, the outers gain.
The outer cylinders get a helping hand from the inners on the intake stroke. Just as the outer cylinder intake valve is starting to flow the inner cylinder piston is moving up the bore with the intake valve still open, providing a more accessible source of air for the outer cylinder. However, with moderate cams, the amount of charge robbing is only around 5%, but the inners loss is the outers gain with minimal net change.
So just punch more air into the inner cylinder with correct length intake runners and that benefit carries through to the outers. You get a higher useable rev band from the moderate cam and more mid-range torque than any 7/8 port with short intake runners. The short runners virtually suck air out of the intake when the rest of the engine has the potential to make peak torque.
Things get very interesting when you start looking at a bit more cam duration *smiley*
All theoretical of course.
