Home > General Chat > old t3 to a new t3 from turbo technics difference that is
turbo hogster
Member #: 178
stowmaket suffolk
well after much discussion i changed my old original t3 with a .25 exh housing with the recon from the above which use a .36 housing as you can see the housing is a lot bigger but did give some what different result.
the new one comes in later at 3000rpm instead of 2250 , which i think is better as it makes chugging about a bit more ecomonmical on the fuel fron but does come in with a bit more of a bang.
the old turbo gave just 136 bhp at the flywheel on 15 psi which was not very good for that abount of boost
but the new gave 148 bhp at the flywheel on 15 psi but with a few mods to the head and manifold in the winter i can see this getting over that.
ive posted this as some people wanted to see the differnce, when i get round to it i will also post the power graphs as well.
here is the pic.
nice one mate. Shame it didn't make the difference you wanted, can you get bigger!
whats the cost?
turbo hogster
Member #: 178
stowmaket suffolk
£360 all in. with next day delivery they were supub i must admit as i went direct.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
more power for the same psi?
[smug]
That must be somthing to do with more air getting in and out of the engine *wink*
Alex - [/smug]
AlexF
I thought it would be same amount of air, but less restrictive exhaust housing leaving lower back pressure before the turbine.
Sounds quite true to me...
Unfortunatelly Hoggy didn't (I suspect) measure the backpressure. A few on this board have however, so have some proof behind theory*wink*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
How can the same amount of air = more power?
If the power has gone up then more fuel is being burnt! More fuel being burnt also means there is the air to burn it in *happy*
QED.
Alex
AlexF
Stick a potato up your exhaust pipe and go for a run on the 1/4 mile... 10/15 psi of boost will still be generated, but you'll be quicker in a milkfloat.
You can't properly size a turbo without taking backpressure into account - what is blatantly clear is that the 0.25 is restrictive on the exhaust.
I'm really amazed you can't figure this out...
turbo hogster
Member #: 178
stowmaket suffolk
totaly agree td, the exhaust housing appeture was tniy compared to the new .36 housing so greating less back pressure which in turn on the overlap will then flow back up the inlet track which was evident when i once removed the head and found on every single inlet around the port a heavy carbon build up.
as one would say if you are chucking it in its got to get out the esier the better with comprimising flow.
thus the difference between a rc40 exhaust and a bog standard one.
and the proof is in the pudding but it would be handy to read or measur the back pressure but god nows how you would do it.
turbo hogster
Member #: 178
stowmaket suffolk
also you have got to take in to acoount that in a ideal world you want is say 15 psi at the top of cylinder with the piston fully down the bore, but as we take the reading in the inlet manifold here also there could be a loss of say 2 psi, eg 15 psi on the gauge and only 13 psi in the cylinder due restriction in the inlet track but would be hard to get a reading of this.
as in the vizard book says you want to make bannanas not psi.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Dave I have figured this out...
What your saying is totally correct!
Alex
AlexF
sounds like sarcasm!
Anyways - Rich, are you happy now, or are you still thinking there is more hiding away? I note your elbow hasn't been opened up aswell?
Despite the boost coming in later, is there a difference when it does (eventually - LOL!!!) start spooling - ie at 4000 rpm or similar, when you stamp on the loud pedal does it get to full boost as quickly as before, or a little slower?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
not trying to be sarcastic (bar the being smug bit... that was an attempt at humour)... sorry if it came across that way...
Alex
AlexF
Sarcasm is humour!!! LOL!
Main thing is Richard happy yet?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
not to you americans *wink*
AlexF
Hey - Mouth!
English and Proud!
I may drive an F-150 but it's got an England flag on the tailgate and a 'Chorley FM' sticker in the rear window!
dan
Member #: 93
not exactly the same, but nonetheless back pressure related, but when I replaced the std exhaust system on my old r5gtt for a more free flowing system I lost about 4psi and had to re-adjust to bring it back to what it should have been
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
time to get rid of my old t3 then, still using the 0.25
16V project underway
Thought you had a hybrid???
If you do indeed still have the .25 (I think you're lying *wink* ) then it's no wonder you needed that absolutely ridiculous boost you said you were running to get a high 13-sec pass!
giallofly
Member #: 164
The Stig..
Newport Pagnell
I have been using a .36 exhaust turbine housing....
Seems to work!
JF.
EDITED DUE TO DECIMAL POIT IN WRONG PLACE, TA MW.
Edited by giallofly on 26th Aug, 2005.
i hope the point is in the wrong place jon *surprised* *surprised* lol other wise your car realy does well to get off the mark like that:)
turbo hogster
Member #: 178
stowmaket suffolk
yes very happy but as dave spotted still some work to do as i think there is still some more galloping horeses to come out of the engine or the same for less boost.
but she does come in with a bit more of a bang especially at 4k
which i a way is good as when you are just chugging about i think the car is a bit more economical as the turbo isnt coming in all the time unlike before but you do lose out in another aspect reel bottom end torque unlike before.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
What cam are you running hoggy?
Whats your ignition time like?
Mine starts to boost at 2.5k and is well on boost by 3k
And its exactly the same turbo you have!
Alex
AlexF
turbo hogster
Member #: 178
stowmaket suffolk
mini williams special cam
mine is about 2.5 to start to boost and is coming in at 3k.
but it has usefull boost at 3k thats what i ment alex
timing is 24 deg fixed
