| Home > Help Needed / General Tech Chat > changing the diff ratio | |||||||
25th Aug, 2005 at 12:56:46am
just wandering how hard this will be to do if i want to change to a 3.1 instead of a 2.9, (dont worry hoggy not going to rip my new box to bits just yet lol) just thinking of the future and if it will make that much difference to the oh my god this is quick feeling! guess the only way is to try it first i guess |
25th Aug, 2005 at 08:20:20am
Engine and box out, diff out of the back, speedo casing off the end, *think* you can just about get your hand/a screwdriver in to push the synchro hubs across to lock it in 2 gears, then undo mainshaft nut and remove pinion. Swap new one in, change crownwheel on the diff, put it all back together, re shim diff etc.
25th Aug, 2005 at 02:11:37pm
I reckon with 1st gear engaged, It'd be pretty easy to undo the MS pinion with the starter ring locked....
25th Aug, 2005 at 04:12:25pm
you will gav but if you are intending having your big buch of bannanas then i would stick with a 2.9 diff until she has to come out anyway for a look over. always looking for them bigger bunches of bannanas |
25th Aug, 2005 at 10:07:40pm
im toying with the idea of a 3.21 diff, at avon i was hitting 7000 just as i crossed the line, and on the road ive managed 105 according to my speedo as i hit it
25th Aug, 2005 at 10:23:57pm
what ratio have you got at the moment nic? i'm gonna stay with the 2.9 for the moment hogsters car runs really nice with it. |
25th Aug, 2005 at 10:26:27pm
7000rpm over the line?
25th Aug, 2005 at 11:18:43pm
3.44 at the moment on 10s
Edited by Nic on 25th Aug, 2005. |
26th Aug, 2005 at 08:42:21am
the advantage of a turbo is you dont need to rev it high unlike NA engines.
