Home > Help Needed / General Tech Chat > Pre-verto to verto conversion
northernminiman
Member #: 11050
Knottingley, West Yorkshire
Right guys question for you all I'm in the process of stripping a engine I was given and it's a pre-verto type clutch. So I was wondering how easy it is to convert to a verto clutch set-up?
Simon
easy peasy,
swap the flywheel and wok with the slave cylinder bracket and arm... you need the short verto arm to get enough throw.
you can use the same slave, the difference in diameter isnt enough to make any real difference.
northernminiman
Member #: 11050
So new clutch, flywheel, wok and slave cyclinder, arm and that's it? Nothing else needs doing?
oh, ring gear might be an issue,
preverto is usually 109 teeth and verto 12somthing... so might need to change the starter... the 12od is a preengaged...
jonny f
Member #: 9894
Dorking
Shameless plug...
You'll need a starter and i have one.
http://www.ebay.co.uk/itm/251936472911
northernminiman
Member #: 11050
Should really have asked this before I asked about the conversion, but is there any advantage to converting over to a verto clutch assembly?
Oh yes! Search rts....
Edited by Joe C on 8th May, 2015.
You will also need a new keyway washer for the centre of the flywheel.
