| Home > Help Needed / General Tech Chat > Primary gear tolerance.... Oil in flywheel housing | |||||||
283 Posts Member #: 8215 Senior Member Rayleigh |
12th May, 2015 at 07:27:37am
Morning
Dave the Cake |
12th May, 2015 at 07:55:13am
Change the bush. If you contact Keith Calver, he's got a man doing it properly. On 13th Jul, 2012 Ben H said:
12th May, 2015 at 09:11:42am
Get a DTI and measure the play, otherwise you're just guessing.
Edited by PhilR on 12th May, 2015. |
12th May, 2015 at 09:20:07am
whats your crank case pressure like? id think if its a bit much it may push extra oil between the crank tail and primary gear
12th May, 2015 at 10:16:11pm
I'll have to get some new bushes bored at work this week as I need the car back together for l2b
Dave the Cake |
12th May, 2015 at 10:22:36pm
I have a oil breather catch can but it does blow a fair bit of oil vapour out Dave the Cake |
13th May, 2015 at 06:12:03am
Found this
Dave the Cake |
