Home > Help Needed / General Tech Chat > struck oil :-/
D4VE
Member #: 10749
lowestoft suffolk
Noticed at weekend my cv gaitor was split... took driveshaft out and fitted new boots each end as inner had split too.. whilst doing all this i was noticing alot of oil drips (normally doesnt drop any oil at all!!) There was oil drip from drivers pot joint and also bit wet round the plugs...
Took the mini out for a spin to check all was ok with the fresh boots etc.. pulled over for a check n there was smoke coming from back of engine... by time i was home it was dark so couldnt really dig into it anymore.. but im really hoping its just all seaping from the rocker cover gasket.. the turbo feed is ok, as is the drain, that all seams dry.. just the back of the block seams wet.. and it looks like its going down to the drivers pot and flicking it onto the downpipe and exhaust tunnel which must be where the smoke is coming from... cant think of anywhere else it would be coming from... i start my new job tomorrow so times gonna be tight for london2brighton! I think the gaskets in tact its just that soaked with oil that its seaping through.... please confirm my thought of this easy fix
Nothing gets past Dave lol
JT
Member #: 637
Hertfordshire
Oh no not another l2b no goer (like me :( !) lol
Hopefully it's just the rocker gasket like you say!
My build thread..
D4VE
Member #: 10749
lowestoft suffolk
Well..... as today was just an induction day i was back on the mini in no time!! Spent ages taking off all stuff in the way like intercooler and pipework, catchtank n pipework and wiped up all the oil from the block (note to others... black engines are cool but not for when ur looking for oil!) I placed new gasket on rocker proper o.c.d style and put it on... put pipework back and got over a problem with the breather pipe to rocker, started it up and tap tap tap... wtf is that!?!?! Rockers hitting the cover.. f*#k.. off it comes again and push it back slightly.. no more tap! *Clapping* wait for a while... no more smoke *Clapping* wait a lil longer and look under the car... no more oil patches! *Clapping* fingers crossed thats it....
jonny f
Member #: 9894
Dorking
yayyyyyy
evad1980
Member #: 10165
Stansted, Essex
Brighton's still on the horizon then!
JT
Member #: 637
Hertfordshire
Nice one!
My build thread..
Nice one see you there
D4VE
Member #: 10749
lowestoft suffolk
Cheers guys Oh i'll be there no matter what!! This will be my 11th in a row *happy*
evad1980
Member #: 10165
Stansted, Essex
Jealous! I'm still yet to do my 1st!!! Next year... I promise lol 😁
D4VE
Member #: 10749
lowestoft suffolk
Ummmmmm...... so i chucked open the garage door.. the piece of carboard i left under it has not one drop of oil on *smiley* went 4 miles down the road and i could smell hot oil.. ( i think right ok so it must be burning off the old oil still? Plus any oil thats still let to drip down back of block?) Left it an hour.. no drops of oil but i can still see the oily patch on the downpipe (not sure if its fresh or still old stuff) drive the 4 miles back... slight hot oil smell but not the puffs of smoke that it did before... will it need longer to 'burn off' ? Is this dangerous to drive like this? Especially to london... then brighton then back this weekend? Lol
when i blew a turbo on the skyline, it took about 100 motorway miles (600 degc egts) untill the oil smell went, that was oil down inside the exhaust though
and i had to flush / pour 1.8l oil out the intercooler lol
3or4 days before mitp awell
jonny f
Member #: 9894
Dorking
Get a few cans of brake cleaner down there!
To be honest my ploy in these situations is buy an aerosol of Gunk or other de greaser then find a jet wash at a petrol station where the attendant can't see what you are doing! Then with engine hot give it the good news with the de greaser and the jet wash, avoid pointing the jet wash at anything electrical and have a tin of WD40 to hand for the plug leads then away you go.
oli79
Member #: 8480
Hahahaha im not the only one then
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
oli79
Member #: 8480
Could it be your driveshaft output seals that are flicking a bit of oil out when on the move?
D4VE
Member #: 10749
lowestoft suffolk
Soooooo.... this morning before work i sprayed some gunk on it... after work i hosed it off, took it for a drive n it seamed to burn off within 15/20 minutes... especially when kickin the arse out of one of them new supercharged se'ats.. and chasing after an audi r8!! Hahaha *happy* no more smoke or smell! London2brighton here i come!
Edited by D4VE on 15th May, 2015.
D4VE
Member #: 10749
lowestoft suffolk
Ive got wrap around my manifold n i think it took a lil longer for it to burn off cos of that absorbtion! The lil flick onto the downpipe (not the big patch like before) i think is just an accumulation of oil from bottom of gearbox that then flicks onto downpipe when at speed
