| Home > General Chat > Manual Valve Spring Bench | |||||||
![]() 54 Posts Member #: 2819 Advanced Member south east, Melbourne, Victoria, Australia |
20th May, 2015 at 05:59:35am
Hi guys
everybody likes free stuff |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
20th May, 2015 at 08:42:45am
I just welded a piece of tube with 2 slots in to a clamp. Tube on top site and screw it close. you can do anything if you set your mind to it...
20th May, 2015 at 09:09:17am
Dismantling= spark plug socket and a hammer. On 13th Jul, 2012 Ben H said:
20th May, 2015 at 11:43:28am
On 20th May, 2015 Vegard said:
Dismantling= spark plug socket and a hammer. I use a lambda sensor socket as you can get a magnet in the side. to re assemble I use one of those tools you just push down on and it clips the collets in. for aquard heads I use a valve spring compressor thats lieka big G clamp. Got to be ohnest, I run a garage these days, and dont feel the need to build a proper bench top setup. but if i were inclined it would involve two wood bases which were "V" shaped so the head can be tiled to any angle, and a simple long lever with a part dropping down to act on the valve spring retainer which can obviously be moved. turbo 16v k-series 11.9@118.9 :)
20th May, 2015 at 10:16:30pm
Trego VFP 50. Admittedly, it's not mine, but it certainly takes all the pain out of disassembly/ reassembly of a 16v head! On 26th Oct, 2004 TurboDave16v said:
![]() 112 Posts Member #: 10125 Advanced Member Zoetermeer, The Netherlands |
22nd May, 2015 at 07:21:22pm
piece of tube with 2 slots under a column pillar drill......... |
