Home > General Chat > Dry deck flanges
Is there any drawings about for the outlets for dry decking?
I know they are not expensive however i have done sod all practice on my lathe so though this would be an easy start, if not i will do some.
Also anyone know the 180 degree degree hose internal dimensions?
Ta
Ahhh. Just back k from the workshop and could have got you the sizes if i'd known!
Will probably be back up in the next few days. Can get you dimensions for the fitting and the hose
Thanks Rob
My stubs are for a 32mm i.d. hose. I would estimate 28mm i.d. and 50mm o.d. at the flange end.
Should be able to measure properly tonight if you like.
adcyork
Member #: 6807
York
I concur with AP. I've made mine for 32mm hoses with a 50mm OD flange. This allows enough flat for an M5 cap head (8.5mm head) to sit against with .5mm clearance to the hose stub.
Thanks guys
Streetscreamer
Member #: 10125
Zoetermeer, The Netherlands
Something like this: also for 32mm inner diameter hose
