Home > For Sale > Turbo Fuel Pump Set-up, Rear Light and some stuff that's getting in the way
Mike-998
Member #: 9774
Buckinghamshire
Having just bought an MPI fuel tank I no longer need the fuel system I had bought previously. This consists of the hardware from the tank to the Fuel Pressure Regulator:
7.5 Gallon Fuel Tank, looks spotless inside and just some external paint chips from having things in the boot
Minispares braided hose from tank to pre-pump filter
Pre Pump Filter - less than 500 miles use
Brass Tee-Piece
Porsche (Bosch?) Fuel Pump, bought second hand, not had much use, works fine. Not been flow tested but having left a hose open and run it accidentally it does work. Also was running fine on an NA car for 500 miles. Includes P-Clips, earth lead and mounting rubbers.
Barb connection for fuel pump
Braided Hose to standard mini fuel line
Stainless Hose for return from regulator
It's almost a complete kit if you still have the standard fuel line, though depending on where your regulator is you may need some extra hose (I had it mounted next to the wiper motor).
I'm after £50 for the lot.
Some pictures:
I also have a set of rear lights, tinted red. Converting to Mk2 lights so no longer needed - £30.
Gauge Bracket painted in black crackle paint - £5
Mike-998
Member #: 9774
Buckinghamshire
Also found an Oil Cooler, I believe off a Cesna aircraft or something. No idea on history so £10? Dimensions are 200x150x90mm
