Home > Wanted > Mechanic for few jobs
robj
Member #: 11059
Anyone in bham
Basically need my ball joints changing both sides as i had 1 shear straight off last night
But also wanted a visual check as to weather anything else needs changing so i need someone with more experience than the little i have. Pm if your available please
D4VE
Member #: 10749
lowestoft suffolk
It is really worth having ago yourself! Youll be surprised how easy it is.. and if you plan on having a mini for a while you best learn anyway cos theyll always need attention
Nothing gets past Dave lol
robj
Member #: 11059
Yep having a go myself under the guidance of neighbour who has many years experience.
Only problem being my passenger hub where bottom ball joint screws on has cracked anyone got a spare 8.4 hub?
D4VE
Member #: 10749
lowestoft suffolk
I think minisport sell the whole hub new with new bearings and ball joints fitted for like £85??
robj
Member #: 11059
hubs going on 2moz morning with new ball joints,heavy duty tie bars,track rod ends gaitors etc but having never set up track rod ends etc im worried the wheels will be all over the place. id still like some help if anyone is local and can lend a hand ill obviously pay for there time cheers bob
Set the steering wheel to straight, then by eye adjust the tracking till both wheels point straight forwards. Then drive slowly to your nearest place to have the tracking done properly.
robj
Member #: 11059
cheers tom just a bit out of my depth and would rather it not happen again. its almost certainly bread and butter to a lot of mini owners but ive never done it before so just a tad worried that 1 wheel will go left and the other right.
robj
Member #: 11059
quick update
a broken thumb and finger has stopped me halfway through this job! so is anyone available this week or next weekend local to b36
robj
Member #: 11059
big thanks to mike-998 who came over to mine yesterday after he had been to work and spent time fixing my poorly mini but not only that took time to show me how to do the jobs i needed doing. robj
