Home > Help Needed / General Tech Chat > Alloy info help
I am looking for some hex bar for a little project I have in mind, but all I can find on eBay is 6082 alloy.
Now I don't know a lot about alloy grades, and I have had a look on the net but it just gets confusing.
So for this thick bloke,, what I am asking is if I was to make a nut out of this grade would it strip if I was to do it up tight ?
Thanks simon.
Sir Yun
Member #: 1592
Smart Guy!
It depends on how tall and what the diameter and profile of the thread on the nut is. If the bloke needs to stay attached say in a crash i would opt for proper steel to be safe. You get galling as well with aluminum on steel thread as well
Edited by Sir Yun on 20th Jun, 2015.
slater
Member #: 1291
Suffolk / Birmingham
6082 is your general purpose alloy really but is actually quite high grade and usually good for most stuff.
7020 is you stronger option i think
