| Home > Help Needed / General Tech Chat > diff question | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
15th Jul, 2015 at 10:19:25pm
so i have some crown wheel laying around that were in a box i once bought many moons ago...
![]() 428 Posts Member #: 10128 Senior Member Dorset |
15th Jul, 2015 at 10:24:40pm
Edit. No, See article below... Edited by e5tus on 16th Jul, 2015. |
15th Jul, 2015 at 10:26:25pm
Almost certainly all originally used as 3.44:1
15th Jul, 2015 at 10:38:39pm
On 15th Jul, 2015 Rammie2000 said:
so i have some crown wheel laying around that were in a box i once bought many moons ago... it seems they have 62 teeth... so if i understand correct i can get 3 pinion wheels to match that crown wheel? 15 17 18 teeth? so those 3 are interchangeable without the risk off getting the tooth jammed? greets No, I don't think they're interchangable - you need to check the part number on the gear; Check this article here... http://www.retrominisltd.co.uk/index.php?m...d=19&chapter=20 From the article: "Some gears have the same tooth count for different ratios, they are not interchangeable - hence the need for different part numbers…. ONLY use in known pairs A+ and pre A+ gears are not interchangeable as they have a different tooth profile." |
16th Jul, 2015 at 07:26:28am
In that case, ignore my bollocks! Glad you pointed out that article Phil, I'm just about to sort my FD. |
16th Jul, 2015 at 08:10:01am
On 15th Jul, 2015 e5tus said:
Almost certainly all originally used as 3.44:1 What FD are you considering? Ill look at the numbers. Well i have a 3.11 on a minisport 4 pin diff now that is was going to use in the turbo. And maybe was going to change to 3.44 if they are usable for that. Still i read up both ratio's are pretty popular for turbo minis ( do remember it to be a bit long for my na back in the days) you can do anything if you set your mind to it...
16th Jul, 2015 at 08:11:19am
Thanks a nice morning read.
so i have some crown wheel laying around that were in a box i once bought many moons ago... it seems they have 62 teeth... so if i understand correct i can get 3 pinion wheels to match that crown wheel? 15 17 18 teeth? so those 3 are interchangeable without the risk off getting the tooth jammed? greets No, I don't think they're interchangable - you need to check the part number on the gear; Check this article here... http://www.retrominisltd.co.uk/index.php?m...d=19&chapter=20 From the article: "Some gears have the same tooth count for different ratios, they are not interchangeable - hence the need for different part numbers…. ONLY use in known pairs A+ and pre A+ gears are not interchangeable as they have a different tooth profile." Edited by Rammie2000 on 16th Jul, 2015. you can do anything if you set your mind to it...
16th Jul, 2015 at 10:45:24am
The only pinion/crownwheel that can be interchanged are the A+ 3.1 and 3.2 ratios On 26th Oct, 2004 TurboDave16v said:
16th Jul, 2015 at 11:14:41am
Minisport x pin is utter shit. In the 13's at last!.. Just |
16th Jul, 2015 at 05:45:36pm
why utter shit? i always seen it as the only good thing comming from them. i have been ridding it previously for 80000km without problems on a 1310 na. you can do anything if you set your mind to it...
16th Jul, 2015 at 06:38:52pm
No one on turbo minis would ever recommend one as tgere have been failures. There have been no failures of the minispares x pin as far as i'm aware. On 26th Oct, 2004 TurboDave16v said:
16th Jul, 2015 at 07:17:28pm
On 16th Jul, 2015 Sprocket said:
The only pinion/crownwheel that can be interchanged are the A+ 3.1 and 3.2 ratios Not according to the tables on the MiniSpares site. The following ratios use common pinions (1 line per pinion part number): A-series 3.65 & 3.76 A-series 4.1 & 4.2 & 4.3 A+ 3.65 & 3.76 A+ 3.1 & 3.2 |
16th Jul, 2015 at 10:03:53pm
That all seems to tie in with the link above, except for...
16th Jul, 2015 at 10:34:42pm
hm. it seems that all this could use some investigation. you can do anything if you set your mind to it...
16th Jul, 2015 at 10:49:39pm
... Or cable ties; Keep them paired up and never worry about it again! |
17th Jul, 2015 at 06:42:23am
On 16th Jul, 2015 PhilR said:
That all seems to tie in with the link above, except for... A+ 3.65 & 3.76 The link above suggests that A+ 3.65 & 3.76 pinions are not interchangable as there are 2 different part numbers for the A+ 17 tooth pinion. The article seems to be a reprint of Keith Calver's work, which ironically leads back to the Minispares site. http://www.minispares.com/article/TCC10001...x?ids=702%7C967 A few other sites seem to confirm there are 2 different part numbers, so perhaps, the only A+ pinion/crownwheel that can be interchanged are the 3.1 and 3.2 ratios The table in that article is all fucked up - there are pre-A+ part numbers in the A+ columns. There's another table on MS site that is clearer: http://www.minispares.com/catalogues/class...box.aspx?1~4~39 A-series 3.65 & 3.76 uses 17 tooth pinion - 22A399 A-series 4.1 & 4.2 & 4.3 uses 15 tooth pinion - 22G99 A+ 3.65 & 3.76 uses 17 tooth pinion - DAM4131 A+ 3.1 & 3.2 uses 19 tooth pinion - DAM2808 Edited by graemec on 17th Jul, 2015. |
17th Jul, 2015 at 07:54:58am
I have them paired up now. But it just seems there are many different opinions about what can be mixed or not. With me the crownwheel states dam.... and 62/18 so dont think it can be mixed up with othzr pinionwheels.
... Or cable ties; Keep them paired up and never worry about it again! you can do anything if you set your mind to it...
17th Jul, 2015 at 08:16:37am
Also take a look at the guessworks site to compare ratios...
432 Posts Member #: 7856 Senior Member Essex |
17th Jul, 2015 at 03:28:12pm
I thought i'd add in one of my bookmarked pages to the thread...
