Home > Help Needed / General Tech Chat > Carb I.D
clubman91
Member #: 8923
North Wales
Hi all,
As title can anyone ID my carb. not taking it of yet so cant measure
It has the little aluminium tag on it MAC 1003 WK 23 92 any help?
And am I right in thinking that port 1 goes to the breathers and port 2 connects to the little steel pipe that runner over the wok and down the block behind the starter motor and is just open?
Mark.
Edited by clubman91 on 17th Jul, 2015.
Looks like an HIF38 to me. Probably of a 998 mini or metro.
Yes, your pipe thoughs are correct. " is for anti run-on valve. 1 should be blocked or to the breathers.
clubman91
Member #: 8923
North Wales
Ok cheers Will, Dose it make any difference if its blocked off or to the breathers.
metroturbo
Member #: 989
North Yorkshire
http://sucarb.co.uk/catalogsearch/result/?q=mac+10031
No real difference between blocking 1 or plugging it to the breathers. Personally I'd just block it.
clubman91
Member #: 8923
North Wales
Cheers will.
