| Home > General Chat > Need change or file myself? | |||||||
![]() 330 Posts Member #: 9628 Senior Member |
18th Aug, 2015 at 11:35:53am
I've got my car running a driving with the help of you guys,
18th Aug, 2015 at 11:36:50am
BDD is standard.
![]() 328 Posts Member #: 9107 Senior Member Devon |
18th Aug, 2015 at 03:26:06pm
My advise would be to get it on a reputable RR with an operator that knows what they are doing . You can always ask for them to show you how to adjust / file the needle if your not sure . |
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
19th Aug, 2015 at 08:54:55am
The BDD is fine in mine with an ever so slight tweak. They don't die, they just get faster! |
19th Aug, 2015 at 09:10:26am
BDD should be bob on at 5psi. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
19th Aug, 2015 at 09:38:33am
I think BDL is a bit richer again than BDD but as others have said BDD should be ball park at least. I've been doing some filing recently and found turbo tels thread really handy if you go that way:
On 7th Nov, 2008 Nic said:
19th Aug, 2015 at 09:44:49am
BDL is leaner than the BDD until stations 13 where it becomes a gnats cock richer than the BDD.
19th Aug, 2015 at 09:51:43am
try one of the SU needle comparison sites; I found it quite useful when deciding what to try
19th Aug, 2015 at 12:07:24pm
Hmmm, would it be a carb problem if it's going lean at high boost? Or just down to the spec, I will be booking it in for a rr early next year as I won't be using it again from early September.
On 19th Aug, 2015 Shauna said:
The BDD is fine in mine with an ever so slight tweak. What spec is your engine? |
19th Aug, 2015 at 02:55:00pm
if you meant to type BBD ,then here is a comparison between BBD and BDD
19th Aug, 2015 at 04:00:51pm
On 19th Aug, 2015 robert said:
if you meant to type BBD ,then here is a comparison between BBD and BDD ![]() Oh I didn't notice that, when i checked it it was the same as the standard needle, so BDD |
19th Aug, 2015 at 04:31:09pm
On 18th Aug, 2015 John said:
BDD is standard. BCA is a well rich needle. I've got a BCA to go in mine, better to be on the rich side. I did get it running with a BDD but haven't driven it yet, so couldn't say what AFRs I'm getting. |
19th Aug, 2015 at 06:28:06pm
Shaunas 998T runs pretty much bang on with the BDD in it, justvlucky i think! On 26th Jan, 2012 Tom Fenton said:
19th Aug, 2015 at 07:34:25pm
On 19th Aug, 2015 Carlzilla said:
Shaunas 998T runs pretty much bang on with the BDD in it, justvlucky i think! what was her spec? would be intresting to compare figures |
19th Aug, 2015 at 07:35:29pm
19th Aug, 2015 at 08:48:10pm
On 18th Aug, 2015 coopdog said:
I've got my car running a driving with the help of you guys Donate button is top right, would you have managed it if this place ceased to exist???
19th Aug, 2015 at 09:38:52pm
We ran fine with it on 8psi and it's still fine on 10.
Shaunas 998T runs pretty much bang on with the BDD in it, justvlucky i think! what was her spec? would be intresting to compare figures They don't die, they just get faster! |
