| Home > Technical Chat > Source for electronic components - injector driver | |||||||
10th Sep, 2015 at 04:41:05pm
Gents
10th Sep, 2015 at 06:55:24pm
Might be worth an email
Edited by gr4h4m on 10th Sep, 2015. I run a supercharger and I don't care the TB is on the wrong side.
10th Sep, 2015 at 06:56:53pm
Isn't peak and hold done with another chip and various resistors on the board? Those control the transistor so that it peaks and the holds the current at a value set by the resistors? Is it just the transistor you need? On 26th Oct, 2004 TurboDave16v said:
10th Sep, 2015 at 07:03:34pm
Ah, ok its a complete package in one....... On 26th Oct, 2004 TurboDave16v said:
10th Sep, 2015 at 07:19:21pm
I think if these were still available in some form, the megasquirt lot would be all over them. I know Jean has a peak and hold driver board that use a peak and hold driver chip and a standard type three pin package transistor. I may have one of these boards built up somewhere, if I can find it, its yours if you can cobble the parts for your needs. On 26th Oct, 2004 TurboDave16v said:
10th Sep, 2015 at 08:50:46pm
Cheers gents. I have the relevant datasheet.
10th Sep, 2015 at 08:51:50pm
Was going to say i doubt any purpouse built peak and hold driver ic's exist these days, modern microcontrollers are so fast all you need is a suitable generic igbt/fet and a shunt and the rest is done in software. turbo 16v k-series 11.9@118.9 :)
10th Sep, 2015 at 08:56:14pm
16 ohm shouldnt need peak and hold tom a fet/igbt that can handle the current should do the job. Peak and hold drivers are required for low impedance injectors as the energise the injector untill the coil in the injector saturates then they drop the voltage to the coil to hold it open wothout burning it out. A 16 or so ohm injector should tollerate battery voltage across them constantly. turbo 16v k-series 11.9@118.9 :)
10th Sep, 2015 at 09:16:24pm
I'm still a novice at this so only trying to piece together what I can from datasheet etc.
10th Sep, 2015 at 09:24:25pm
Ive got to be ohnest i think there overkill for a 16 ohm injector, drive current at 14.4v will be just under 1 amp and the higher current one should be able to drive a low impedance injector. Any chance of a link to the circuit or datasheet? turbo 16v k-series 11.9@118.9 :)
10th Sep, 2015 at 09:32:10pm
you shouldnt need peak and hold with 16ohm injector
Yes i moved to the darkside |
10th Sep, 2015 at 09:34:02pm
Yeah the peak and holds are normally used for low impedance injectors. A lot of the early injection stuff use to be low impedance. Nowadays injectors are mostly high impedance with the exception of some super huge flow injectors. On 26th Oct, 2004 TurboDave16v said:
10th Sep, 2015 at 09:59:25pm
Data sheet for the L9335/6 here
11th Sep, 2015 at 12:50:34am
On 10th Sep, 2015 Tom Fenton said:
Cheers gents. I have the relevant datasheet. I think the issue is that someone has fitted the wrong injector, a 4ohm impedance instead of the correct 16ohm. I think this has fried the injector driver. What driver chip do the MegaSquirt use? A 4 ohm typically would be a P&H type, 16ohm would be normal simple off/on. No damage should occur fitting the 16ohm to the P&H driver, but damage could occur fitting a low impedance injector to a normal saturated driver as it can draw too much current But even in that case, in reality both draw very low amounts of current, so I'd be surprised if it would damage the drivers themselves unless someone actually created a short circuit. 9.85 @ 145mph
11th Sep, 2015 at 08:30:53am
http://uk.farnell.com/texas-instruments/lm...-dip/dp/1564728
11th Sep, 2015 at 09:25:06am
What driver chip do the MegaSquirt use? Only just seen this... LM1949 (as Denis has said) but in conjunction with a TIP122 darlington driver (a large high current transistor) like Colin and Denis said and a few external resistors / capacitors. The LM1949 is just an 8 pin integrated circuit chip (ie, doesn't handle the current itself, it just switches the big transistor on and off). The basic principle is the same as the one you have, the ratio is usually 4:1 on current but the LM1949 also has an external capacitor in its circuit (see the datasheet) that determines the time duration of the peak current. Jean's board will take up to four of them (as they are usually used for main banks of four injectors) and also has an active flyback circuit (limits induced voltages which low z injectors tend to create and improves their closing time). But. as already said you shouldn't really need a Peak/Hold drive for a 16ohm injector. A peak and hold drive will work fine with any injector but high z nowadays are usually just driven with a simple MosFet (another type of transistor) with suitable ratings which is usually just driven from a CPU output pin through a simple resistor. From your description it sounds like the device you have is being driven from a timer circuit off the coil, but the principle is the same, low current source switches a high current transistor type device. The main reason for Peak and hold is not any current limitation of a MosFet against a Darlington driver, it's to protect low z injectors from overheating, if full current was flowing all the time they were open, they would get very hot and fail. EDIT - typos Edited by Rod S on 11th Sep, 2015. Schrödinger's cat - so which one am I ??? |
21st Sep, 2015 at 03:08:42pm
Gents
21st Sep, 2015 at 03:24:03pm
yeh |
21st Sep, 2015 at 05:15:43pm
Good result! Team www.sheepspeed.com Racing
