Home > Help Needed / General Tech Chat > got some new stuff in a box but need help id some things...
Rammie2000
Member #: 10190
belgium
No idea what it is... anyone?
Some more stuff...
Also a weber dcoe40 and twin hs4 carbs ( both complete)
Rammie2000
Member #: 10190
belgium
What are the bearings right hand side on bothem of pic? The 4 in the plastic bag. ?
Rest is all gearbox stuf.
Grts
Rammie2000
Member #: 10190
belgium
Rammie2000
Member #: 10190
belgium
Rammie2000
Member #: 10190
belgium
Them rings
Edited by Rammie2000 on 24th Sep, 2015.
Rammie2000
Member #: 10190
belgium
Box looks like shit but rings like new.
These pistons stil get made?
jonny f
Member #: 9894
Dorking
Alloy blocks are for an anti roll bar.
The bearings look like diff out put cover ones.
PhilR
Member #: 10034
Birmingham
The 4 bushings look like ones in the diff side covers.
PhilR
Member #: 10034
Birmingham
Starter motor brushes in the blue and red boxes.
Rammie2000
Member #: 10190
belgium
Okey thnx.
I tought the brushes came from a alternator so thnx for the info.
As for anti rolbar. Any pics of how and where to use them? Might find the bar to.
All the things in the top picture are for a rear anti roll bar, the blocks bolt to the rear subframe, the the sliders bolt to the arb which then bolt to the rose jointed droplinks, to a bracket on the radius arm (not there)
My mates on the back of his busa mini.
Rammie2000
Member #: 10190
belgium
Looks easy enough to make the rest of that stuf needed. Grts.
The shear loading on that looks really shit
I have the brackets shown on this kit with mine, they look a bit sturdier.
Edited by Carlzilla on 26th Sep, 2015.
Rammie2000
Member #: 10190
belgium
Brackets look easy enough to make.
Someone here has some mesurement of the rolbar itself? Stupid thing is.... ( yes very stupid) i had one 2 years ago. ( only the bar) but needed some round qteel to make a rear set footpegs for the race bike so i cut it up...
Normally 5/8 or 3/4 dia, the 3/4 is a bit too much for frequent/daily use I've read
graemec
Member #: 1424
Carnforth, Lancs
Measure the hole diameter in the parts you have? If you don't use that size bar then they're useless!
jonny f
Member #: 9894
Dorking
You can just use normal steel it need to be Spring steel according to KAD
Rammie2000
Member #: 10190
belgium
I got 15.5 mm holes. Spring steel... i can ask at the lokal dealer.
Does make sence.
That'll be for a 5/8 rear arb then
Rammie2000
Member #: 10190
belgium
Ordered 5/8th spring steel bar at a local shop. He did warn me it won't be easy to bend but will see.
Any one knows these?
Outer size is 76mm ( rough) inner 35 mm and they are 17.5 mm thick. About same dize as diff bearings but thicker. I have 4 of those.
