| Home > Help Needed / General Tech Chat > k1100 build with external oil pump | |||||||
11 Posts Member #: 11213 Member |
29th Sep, 2015 at 11:32:40am
29th Sep, 2015 at 12:17:06pm
Not meaning to dismiss it but Why? It's pretty easy to take a feed out of the sump plug and put it back in the blanking plate on the back of the box.. Or somthing simlar.. Then make a dummy oil pump. |
29th Sep, 2015 at 01:31:59pm
The reason is I want to get rid of the jack/camshaft to reduce the rotational mass, it also means I can get rid of another pulley and oil seal on the engine. |
29th Sep, 2015 at 02:30:37pm
The inertia of the shaft is bugger all. I there was zero friction in the bearings, imagine trying to spin the shaft be hand just be itself and also with the crank and flywheel attached. I asked a very similar question some months back and a big problem is the power needed to drive the pump. You need to find another way to drive the pump and that's electrically you'll still be loading the engine through the alternator, with hefty inefficiencies on top. |
29th Sep, 2015 at 03:36:11pm
I thought about it, there are electric pumps what can do the job, but if that fails, your simply fucked! Team www.sheepspeed.com Racing
29th Sep, 2015 at 08:49:08pm
I quite like having the extra pulley, as it helps shorten the run of the belt between the cam and crank pulleys, and helps keep the tension on it.
Edited by matty on 29th Sep, 2015. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
29th Sep, 2015 at 10:37:10pm
one reson i can think of is dry sump? but ether way i really dont think electric is the way if the factory pump was taken out id go with a gear style belt drive like on drag cars in witch case still have a pully and be just as much hp drain if not more
30th Sep, 2015 at 09:19:18am
I think you would be better doing some more development on a roller bearing supported jackshaft. That's my next project on mine.
30th Sep, 2015 at 12:14:16pm
What's wrong with oil film plain bearings on something that carries little load compared to what they use to? To justify the complexity of roller bearings or, doing away with it all together?
30th Sep, 2015 at 03:28:10pm
Journal bearings cause much more drag especially considering the cam sized journals are now overkill for the jackshaft. If you can turn the lobes off then you could just as well turn the journals down to fit a bearing and also make sleeves to fit the bearings into the block.
30th Sep, 2015 at 09:01:17pm
Why not just machine the jack cam stupidly think and do the jounerals on the bearings make them skinnier |
1st Oct, 2015 at 12:16:19pm
For me it's 25% for drag reduction 25% weight loss and 50% somthing new to play with.. |
1st Oct, 2015 at 11:17:05pm
if you have the tools to turn the cam down and put roller bearings in then its simply a case of why not? whats to lose as Slater says
