| Home > Technical Chat > Actuator pipes!!! Help | |||||||
![]() 18 Posts Member #: 11223 Member Felixstowe, Suffolk |
1st Oct, 2015 at 02:52:31pm
I'm finally getting to the bottom of my engine failure on the Dyno..
Edited by Rich123 on 1st Oct, 2015. |
1st Oct, 2015 at 03:54:48pm
I've got the open end going to my bleed valve. if you had it open to atmosphere you will have effectively been getting as much boost as the turbo could muster so a strong likely cause of your failure |
1st Oct, 2015 at 03:57:16pm
what kind of actuator, if it was the type with two pipes one either side of the piaphragm then the one closest to the wastegate rod should be left vented. (i.e. R5GTT type)
1st Oct, 2015 at 03:58:30pm
On 1st Oct, 2015 Rob Gavin said:
I've got the open end going to my bleed valve. if you had it open to atmosphere you will have effectively been getting as much boost as the turbo could muster so a strong likely cause of your failure The RR guy blocked the pipe. As he should. (if im reading that correctly and it has the type of actuator i expect it has lol turbo 16v k-series 11.9@118.9 :)
1st Oct, 2015 at 04:22:30pm
It's got a uprate avo bar actuator.. It's the type with one either side of it? |
1st Oct, 2015 at 04:22:59pm
P.s thanks for the help evolution! |
1st Oct, 2015 at 04:49:12pm
Ah slight bit of confusion.. I will get a photo up when home :) |
1st Oct, 2015 at 04:58:01pm
Simple test as follows. Connect a tyre foot pump to the actuator stub pipe that was piped to the turbo. Leave the spare stub open. Pump the foot pump. If the actuator rod moves, your RR guy was wrong to block the pipe. If it doesn't move and the air comes out of the spare stub, he was right to block the pipe.
1st Oct, 2015 at 07:39:41pm
I missed that from the first post
I've got the open end going to my bleed valve. if you had it open to atmosphere you will have effectively been getting as much boost as the turbo could muster so a strong likely cause of your failure The RR guy blocked the pipe. As he should. (if im reading that correctly and it has the type of actuator i expect it has lol |
2nd Oct, 2015 at 03:25:04pm
I read this as two pipes from the brass Union on the turbo not the actuator.
In the 13's at last!.. Just |
2nd Oct, 2015 at 05:11:26pm
That is exactly what I thought Gary |
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
2nd Oct, 2015 at 08:54:25pm
Ok so on a normal setup... It should be left vented to atmosphere? |
3rd Oct, 2015 at 06:08:52am
NO, as stated earlier, if left open it will allow the turbo to run amok. |
3rd Oct, 2015 at 11:36:52am
It was originally connected to the boost solenoid, so it should be blocked or connected to a bleed valve/boost controller. |
3rd Oct, 2015 at 03:41:51pm
This thread has some handy drawings.
http://www.twin-turbo.co.uk
336 Posts Member #: 9941 Senior Member Derby |
4th Oct, 2015 at 08:02:29am
Rich 123 the best way to explain how uve piped the actuator up is do us a drawing |
4th Oct, 2015 at 11:03:48am
On 2nd Oct, 2015 evad1980 said:
Ok so on a normal setup... It should be left vented to atmosphere? No! The fitting from the turbo supplies the actuator with boost pressure, opening the waste gate. If there is a leak (leaving the opposite side of the fitting is a fucking huge leak) the pressure is lost and the waste gate doesn't open. This is how a bleed valve works. In the 13's at last!.. Just |
4th Oct, 2015 at 09:26:19pm
Ok guys thanks, I got it. Was just trying to figure out what to do then with the open nipple.
