Home > Help Needed / General Tech Chat > Pedal box issue
burnard
Member #: 10984
Reading
Hi guys,
I would like to know if anyone else is using the wilwood pedal box, the same as supplied in the minitec kit.
I have the mounting plate from mintec and the same pedal box that they use but I am finding that I get quite a lot of flex in the way it is fitted, Does anyone else experience this?
If you have a different mounting system other than the minitec style or have found a solution to this then I would love to see it!
Chris.
adcyork
Member #: 6807
York
I've fitted a different variant willwood pedal box and made my own mount. There's pics in my project thread
Edited by adcyork on 17th Oct, 2015.
burnard
Member #: 10984
Reading
Hi Adcyork, Could you possiby provide a link to your build thread? Ive done a search on your username but it shows zero results :/
jonny f
Member #: 9894
Dorking
I got one, mines tied to the Rollcage though, only way I could see it not flexing.
adcyork
Member #: 6807
York
top hit in the search mate - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=517551
Edited by adcyork on 16th Oct, 2015.
Nick
Member #: 154
Midlands
tied mine into the roll cage and bulkhead
What pedal box are you guys using?
jonny f
Member #: 9894
Dorking
Wilwood dual bias from rally designs.
burnard
Member #: 10984
Reading
Thanks guys, So it seems that the minitec bracket isnt really man enough for the job.
What it does it tie into the original locating points so its flexing on the dash bar. I did make a steering bracket which tied the dash bar to the roll cage dash bar, but it doesnt seem to have helped. I think I will beef that up and add some bracing on the other mounting points on the pedal box.
Cheers for the pictures guys :)
jonny f
Member #: 9894
Dorking
Oh and a tip! Don't press down on the cylinders dry, run a little fluid through them.
The seals will pop of on the inside.
