Home > Help Needed / General Tech Chat > A/R turbo help
lanxter
Member #: 396
sheffield/rotherham
i have recently aquired a turbo which i beleive to b a t2 with the A/R of 48. could any1 tell me the kind of spool up times and power i could run on this item?
also is the any way i could check up what turbo it is.
i have found 2 number found on the side of the turbo which is:
465485-1
77008530653-5
any hel0p would b much appreciated.
thanx
mark
speed is the best rush i have ever had!!!
add me lanxter@hotmail.com
I asusme you mean turbine A/R?
Just fit it - you won't be dissapointed!
lanxter
Member #: 396
sheffield/rotherham
yes dave i mean the turbine A/R. the 2 measurements i have on the turbo that both say A/R are 48 and 49.
will be getting fitted just wanted to check it was the right kinda size
thanx
mark
dan
Member #: 93
sounds like a t25 to me, get it fitted asap as they are a few of us waiting to see what these are like!
lanxter
Member #: 396
sheffield/rotherham
b a fair while yet mate before its fitted, got alot of work to do on the car.
as im totally rebuilding engine first.
money is the main problem im facing with lots of parts to buy. as i wanna do it properly first time.
While we're on this topic, I have a GT17 I was planning to use, the ex A/R is 0.43 the intake 0.53. how suitable would this be?
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
your turbo with 0.49 a/r is a T25, it's a liitle large for your 1275 , i would prefer a T2 turbine, don't worry about bosst ,it will make , but a t2 will do the job a lot better;
abot the gt17, it is perfect
fab
excelent, thank you very much.
MajicMini
Member #: 72
I have a T25 from TurboTechnics, and the compressor side says A/R .43, I've been using this on my 1275 and it does the job just fine.
lanxter
Member #: 396
sheffield/rotherham
right thanx lads, ive been doing some looking up and i think its a T25 from a sarb turbo.
will let u know what its liek when on :)
