Home > 998cc > 12g295 or 12g940
longy
Member #: 2727
Bicester
Seeing that 12g295 are getting harder to find in good condition and costing as much as they weight in gold if you do find one, are there any disadvantages going for a 12g940? Or it is just not a good idea?
I'm building a 998 with a gt1544, phase 2 cam.
1972 998 TURBO SLEEPER
should be good chris , but if using the 940 head and that turbo i would use a softer cam , a mg metro of kent/piper 260 .
slater
Member #: 1291
Suffolk / Birmingham
Yeh, its a bit of a trade off really. The valves are bigger in the 940 but are shrouded by the bore/pocket a bit more. Definitely a good budget option tho.
As above, keep the valves a sensible size. 33in 29ex is all you need.
longy
Member #: 2727
Bicester
Thanks for the feedback guys, i think ill give it another week of hunting and if i cant find a 12g295 i'll go with the 12g940.
T
longy
Member #: 2727
Bicester
Thanks for the advice Robert, i have been hunting for a MG metro cam, but like with the heads they seem to be hard to find. I'll look at the 260 option though.
Rammie2000
Member #: 10190
belgium
im running a 12g940 on my 998 for 2 years now. no problems so far. do run a metro cam in it.
longy
Member #: 2727
Bicester
Thanks Rammie
longy
Member #: 2727
Bicester
Thanks Rammie
The MG cam also the Kent 500 cam, still available off the shelf.
longy
Member #: 2727
Bicester
Cheers Will
Shauna
Member #: 10424
Swansea boyo!
I've got a 295 on mine, took me months to find a good unskimmed one. Really hope I never end up doing any damage to it!
Chalkie
Member #: 9764
Northamptonshire.
+1 will be running a 295.
But a 940 can be used just need pockets I did upload the drawing for people to use
longy
Member #: 2727
Bicester
i saw many thanks chalkie
longy
Member #: 2727
Bicester
I have run both, the 940 has made more power
