| Home > Help Needed / General Tech Chat > new engine setup | |||||||
2nd Sep, 2005 at 11:51:44pm
now simon has all the bits just wondering if someone can give advice on setting up a brand new engine, all i know is you have to turn it over without plugs in to get oil pressure, how many miles roughly will it take to bed the engine in? also can someone please explane ignition advance/retard etc and what welding the dizzy up does as i never got this |
4th Sep, 2005 at 09:12:19am
well gav i would run in at 3k rpm for the first 500 miles gentle paeddal pressure, then no more than 3500 rpm until 1000 miles still gentle pressure and low boost say no more than 4 psi.
6th Sep, 2005 at 11:49:01pm
nice one mate sounds good will prob give you a ring if i make it all go wrong lol, who's that rolling road you and matt use? |
271 Posts Member #: 653 Advanced Member Cambs |
7th Sep, 2005 at 12:41:32am
Run it in quick and it'll be quick.
Its only a bit of metal. If it blows it blows!
7th Sep, 2005 at 06:49:08am
yes but the need to and the rebuild them very often.
7th Sep, 2005 at 10:33:08pm
cheers mate whats the point of welding the dizzy then is it recently necessary? |
8th Sep, 2005 at 06:24:45am
keeps control over the centruifugal advance eg you dont get none. essential for when the boost comes in and you get a steadey ignition timing, last thing you want is spark scatter when on boost, but some people dont do it but i do and does work ok. always looking for them bigger bunches of bannanas |
8th Sep, 2005 at 10:24:43am
Yes works well for me too, i run locked 25deg but have connected vacuum advance for a bit more economy when cruising. Allthough some engines dont respond well to this it must be said. -MINI CLUBMAN 1380 TURBO- |
8th Sep, 2005 at 10:44:36am
The only thing you are really running in on a new engine is the rings.
8th Sep, 2005 at 11:15:42am
I dotn agree with long run ins either...
AlexF |
8th Sep, 2005 at 09:19:39pm
well i did say oyher people had there one opions and each to there own.
9th Sep, 2005 at 02:03:28pm
I suspect your modern engines are manufactured using better machines than those used to re-bore rattly old A-series units...
9th Sep, 2005 at 02:41:27pm
I'd be pretty pissed off if some one was boring my A series to less accuracy than a modern production engine, just cause the design is like 50 years old dosent mean it don't need the same build quality as a modern motor. On 28th Aug, 2011 Kean said:
9th Sep, 2005 at 06:35:41pm
Stand by to be pissed off then...
10th Sep, 2005 at 05:52:39pm
totaly agree dave, also see what rover, ford ect chuck away aswell you would be outstandard of the srcap.
10th Sep, 2005 at 05:56:58pm
alsao all modern engine uses liners which are hard as fuck always looking for them bigger bunches of bannanas |
11th Sep, 2005 at 12:34:58am
cheers guys, is it worth disconnecting the vaccuum then, am a bit confused between initial ignition timing setup and running "locked 25 deg" etc |
14th Sep, 2005 at 07:37:44am
On 08/09/2005 11:15:42 AlexF2003 said:
1st start... get it started and run her at 2-3 rpm up and down for 20 mins to bed the cam in. DOnt hold the revs steady! Alex Why not? On 13th Jul, 2012 Ben H said:
14th Sep, 2005 at 06:39:10pm
I'd say because a fixed speed will polish the bores in a certain way. Varying speed avoids this.
cheers, gav
