Home > Technical Chat > Clutch Case Gasket Thickness
Doodmeister
Member #: 149
Alberta, Canada
http://www.minispares.com/Product.aspx?pid=37172
Why is this Special and what the thickness? Anyone know.
I've measured a piece of the one that I?ve just removed and it's around 0.026", Compared to a new one I have that?s 0.040" which would put me way over on the clearance for the idler gear even with the 0.138/9" shims on both sides.
Does anyone have a few gaskets they could measure and post the thickness to give me an idea of the range of thicknesses they come in?
SumpNut
Member #: 28
Remember your new gasket is uncompressed, once its clamped up, it should compress a bit.
To measure your end float you need to connect the transfer case to the gearbox to measure the idler clearance, that will give you a good idea if your new gasket is soo big or small.
Nick
Member #: 154
Midlands
from what i've found karl is that the decent minispares gaskets sets have thin gaskets whereas the normal conversion sets have really thick black gaskets.
I think i've got a couple of different types ont he wall in me garage but keans just had his verniers back so i cant measure em for you sorry.
just measured a gasket from minispares (new)
0.031" or 0.8mm
how much it compresses you will have to see!
Doodmeister
Member #: 149
Alberta, Canada
Ben is that the NON asbestos one they do (22A2237B) if so I?ve just ordered a few.
Plus the one I have new in the garage is 0.040" and looks very OTT on the thickness.
When I measured all the components and worked out the idler shims needed without taking into account the compression of the gasket I couldn't get big enough shims to take up the idler gear end float so the 0.031" gasket will work a treat..
Cheers for that
Karl.
DOOD
yes go for the 0.031" Idont think it will compress much.
(may be to your benefit????)
just ask for RICHARD at minispares NORTH and ask for a btm end set which they have in stock!
richard is a nice guy*happy* & you can talk to him he is on the same frequency as most of us, but his hands are tied as he cant get the parts they SAY they stock!!! *wink**wink**wink**wink**wink*
all the rest of the employees think they are doing EVERYONE A favour!!!! personally i would sack the lot
civility costs nothing!*smiley*
oh! the price http://www.minispares.com/SearchResults.as...1&ss=0|ajm206ms
this is the one you want carl
oh! and the clutchprimary oil seal go for this one as its a lot more tough!!!
part number LUF10005
http://www.minispares.com/SearchResults.as...1&ss=0|LUF10005
BEN:
Edited by BENROSS on 8th Sep, 2005.
Rich in minispares north is a top bloke! lot of time for him.
must agree jimster
this guy is bursting with knowlage what makes the grade what wont
he is so cival hese like your long lost friend & he will go well out of his way to help you
A TOP GUY
RICHARD minispares north tel:01484 722977
order all your bits there.
