Home > Help Needed / General Tech Chat > Overbore forged pistons
kezzboycat
Member #: 10371
leicestershire
anyone using a alternative forged piston choice other than plus 20 ? There seems to be shorter market With a suitable dish size ?
The only ones that I've come across is the isas forged Pistons.
Has anyone had experience with the above make ?
I'm not sure that Omega still stock Accralites. These were available with 18cc dish in lots of sizes.
If not I'm sure omega do an alternative.
kezzboycat
Member #: 10371
leicestershire
Omega/accuralite only do plus 20 in 18cc on the shelf but They would do other size at a large pop for one offs as I enquired for some 1380 18cc onesbut there just to expensive in my book
But I'm not after that much of dish around 10cc would be fine I've been looking at some forged isas ones from minispeed just wondering what there like seem well priced but are they going to be chocolate or not
Ah. That's annoying. When I built mine you could still get the bigger dish in all overbore sizes.
I'd considered these, as they come in 73mm. Seemed to weigh a ton when I picked one up though.
kezzboycat
Member #: 10371
leicestershire
your one of the lucky ones
kezzboycat
Member #: 10371
leicestershire
no link but yes i think the same ones im on about,intresting im going to have the dish increased so weight will slightly reduced slightly plus id stop eating packs of biscuits and cut down the mcdonalds so make up for the more weight they are just not herd anything about them to be honest
kezzboycat
Member #: 10371
leicestershire
abit of a bump on this
sorry if its boring
use cast omegas there well up to the job
have a look what MED has go in at the moment
and avonbar as ian has set it up again
have a look at JE pistons there all the rage in the states, i think minispeed do them
hope this inspires you
jonny f
Member #: 9894
Dorking
http://dt-vps.co.uk/calverst.com/cart/inde...&product_id=108
Any use?
I rate calver highly.
Johnny, no no no. I removed a set of new ones from an engine what was smoking badley. A new build and the piston skirts was oval by 0.020" and the ring lands had cracked the engine only did 20 miles,
I fitted omegas job done, those pistons I would not put in a concrete. Mixer engine.
how about getting them disshed to what you need, pretty simple job.
jonny f
Member #: 9894
Dorking
My bad!
kezzboycat
Member #: 10371
leicestershire
i was considering that joe c with these
http://www.minispeed.co.uk/content/forged-...dish-73mm-bore/ there said you can put a fairly large dish into them
med they trying to sell me the plus 20 forged
the alternative was the cast omega plus 40 but they didt know if they had in stock or not
didt realise avon was back for bussiness shall have a look there
kezzboycat
Member #: 10371
leicestershire
well the alternative had been je Pistons let see what they can with stand
