Home > Help Needed / General Tech Chat > Crank sensor bracket fouling fan belt
JT
Member #: 637
Hertfordshire
Hi
I have a tom Fenton crank sensor bracket/damper set up.
I've got it all fitted up on the bench. Using a nippon denso alternator.
I put the fan belt on and it fouls the bracket.
I've had a look and it looks like I'm going to have to make a spacer. Not the end of the world but just wondered if this is the norm?
Thanks,
Josh
My build thread..
Where is it fouling? The bracket is intended for the standard alternator and belt. But lots of folk have fitted it with a Nippon alt.
JT
Member #: 637
Hertfordshire
Yes I thought that too tom.
I'll get a pic next time I'm in the barn.
My build thread..
i think you can fit the belt under the bracket or over it i fell in the same trap and i have a nipon alt
toms brackets and pullys are superb
JT
Member #: 637
Hertfordshire
Yes they are very well made.
Just a bit mythed by this lol.
I'll try and get a pic tomorrow evening
My build thread..
JT
Member #: 637
Hertfordshire
here's a pic
My build thread..
You need spacers mate, I made 3 up.
They go between the bracket and engine
JT
Member #: 637
Hertfordshire
yes si. I was thinking the same thing.
just wondered if anyone had come across this before?
Would it be ok to use washers? or should I make a metal gasket type thing to go between?
My build thread..
metroturbo
Member #: 989
North Yorkshire
I had to space my bracket so that the sensor was looking at pulley teeth fully, and yours looks like where mine would be without being spaced. I'm running a nippon alternator as well, and the belt is close but doesn't ever touch.
I used washers, to get it working and then when I was happy it was going to work, I made a spacer up in the lathe.
The bracket is made deliberately narrow. It's easy to space it off with washers, but difficult to make it narrower if it's too wide. The pulley position is different on every engine due to tolerances in the crank, thrusts, timing chain gear, shims, etc
JT
Member #: 637
Hertfordshire
I see Tom. I reckon a couple of washers will sort it.
As you say it's easier to space it out than machine down! :)
My build thread..
mine only just missed the belt but i had a random misfire at about 4500rpm.. took months of pissing about and i eventually figured the vibration in the belt was slapping the sensor at almost exactly the same rpm every time hahaha
