Home > Help Needed / General Tech Chat > Turbine housing temperature?
steve w
Member #: 1917
AKA chargedzetec
Anyone have any idea how hot the outside of turbine housing gets?
I've got to blank off a recirc valve and was going to use something good for 200 degrees??
Compressor? That would do ..
Yeh the turbine is the hot side, anywhere up to 900 degrees and sometimes above if you're brave *happy*
The compressor is the cold side, temperature depends on compressor efficiency and boost, 100 degrees and sometimes above, again depends how brave you are *hehe!*
steve w
Member #: 1917
AKA chargedzetec
Yeah, of course the compressor side!
I just figured that heat soak from the exhaust side may have been more of an issue.
Sound, wanted to use Viton as the gasket as well so all good then.
I have seen EGT temps of 1200c
Jim, its ok, your car is yellow
If this is for the ford turbos where they have the re - circulation/blow off valve is there are some quite cheap kits about made from ally.
http://www.pumaspeed.co.uk/product-Pumaspe...ST250_15581.jsp
steve w
Member #: 1917
AKA chargedzetec
Yeah, it's for a ford turbo. Sort of....
Mine never made official production, so I'm not really sure what blank I'd need. So have made one.
