Home > Wanted > Camshaft / 12g295 / 1.5° negative camber lower arms
longy
Member #: 2727
Bicester
Im after a MG Metro or Piper 255 camshaft, if not would settle for Kent 266 cam. an unmolested 12G295 cylinder head and 1.5° negative camber lower arms
1972 998 TURBO SLEEPER
I have some neg camber bottom arms, with poly bushes. Will pm you.
longy
Member #: 2727
Bicester
im interested
blister
Member #: 2590
Croydon
I have a 12g295 its only missing the inlet valves and inlet valves springs
No longer have a A series engine it's been stored a few years but still clean and painted original mowog green £100 delivered
longy
Member #: 2727
Bicester
Sounds great, do you know if it's been skimmed would you mind measuring the thickness
I may have a cam, what's the number on it?
longy
Member #: 2727
Bicester
I believe the original MG Metro cam had three bands around it, 255 or 266.
I will have a look in my cam box when I am down the cave next, pretty sure I have.
longy
Member #: 2727
Bicester
Cheers Simon.
longy
Member #: 2727
Bicester
Simon, my bad the MG cam doesn't have three bands it has a single groove, between the first and second lobe from the timing gear end.
blister
Member #: 2590
Croydon
Yeah that's fine I'll measure when I'm Home
longy
Member #: 2727
Bicester
could also take a few pictures, thanks
kezzboycat
Member #: 10371
leicestershire
I have adjustable bottom arms if any good and I think I may have cam shall have a look later
longy
Member #: 2727
Bicester
Cheers, ive managed to get the bottom arms, but please do have a look for the cam
There is also the kc500, same as n/a mg
Stamped oil pump end
I have a good KC530 sat here mate.
longy
Member #: 2727
Bicester
Cheers Simon, but the duration is too high (287/281)
blister
Member #: 2590
Croydon
http://i370.photobucket.com/albums/oo146/b...0105_170603.jpg
longy
Member #: 2727
Bicester
Cheers, 69mm is OK been lightly skimmed. Sorry to be a pain but could you take a picture of the chamber face
kezzboycat
Member #: 10371
leicestershire
Well I've checked and One can is fit for scrap and the other cam has a c marked on it any ideas on that ?
blister
Member #: 2590
Croydon
http://i370.photobucket.com/albums/oo146/b..._170742_001.jpg
longy
Member #: 2727
Bicester
Many thanks for looking, not a clue what the C stands for.
