Home > Wanted > 2 inch Exhaust Manifold (N/A) & Exhaust system, and 3.9 SC LSD type cwp - WANTED
ministar
Member #: 10760
Derby
Hello chaps,
- What exhaust manifolds do you have for an N/A motor. Any you had before you went turbo? After either LCB or 3 into 1.
- 2 inch exhaust - from manifold backwards... open to options on boxes etc, but 2'' ideally..
- And finally a 3.9 Straight Cut LSD type crownwheel and pinion (new or used). 16/62 config btw.
James
Hi mate,
I may have a 2 box Maniflow setup that's getting retired in the next 4 months all being well. If your not in a rush?
ministar
Member #: 10760
Derby
Hi Simon need it for the start of the season really, so 4 months may be too long. I would buy new, but if anyone had anything decent second hand i'd have it.
So, will say no for now cheers.
James.
I have an sc stainless manifold that has had the mount points trimmed a little
I'm sure you can machine a normal 3.9 crown wheel to fit an LSD if you already have one.
I've never used an SC CWP.
ministar
Member #: 10760
Derby
Well, giving a bit more detail..
I have the SC crownwheel already, but the pinion is lost. Swiftune can't get a matching pinion as the crownwheel is not Quaife part.
Its an early ATB (so requires cwp like the tran x mk6 for example).
I don't have a 3.9 cwp in helical otherwise could have done that - unless anyone has one??
ministar
Member #: 10760
Derby
Graham - Pm coming your way..
I may have a 3.9 in my lock up mate, that I would happily let go.
jamestar
Member #: 9159
Devon
I think I have a stainless 2" link pipe in the shed and a stainless 2" playmini back box with 3" rolled outlet
