Home > General Chat > 998+020 overbore questions.
Rammie2000
Member #: 10190
belgium
not turbo so not sure where to place it. i have "found" a 998 short block +020 overbore. bores look great ( were done when rebuild and never driven since) new flat top pistons etc. pistons sit flush with the block. but thing is. they kept it upside down on a floor and the block has allot of surfrage rust ( head to).
now in my mind there are 2 solutions. get the block and head skimmed slightly as possible and have the piston tops skimmed to. or have them skimmed and see if the pistons do not come out further then the head joint.
any thoughts.
Head looks like it's had work too
slater
Member #: 1291
Suffolk / Birmingham
I don't really understand the question, just skim it and make the pistons flush again as normal..
If you want the lazy mans solution stick it on the grinder as-is. Take a few passes with the pistons at tdc then rotate 180deg and do it again..
jonny f
Member #: 9894
Dorking
No one else think a light scotchbright might be worth a shot?
PhilR
Member #: 10034
Birmingham
Skimming a few thou off each will be fine even if the pistons were just above deck height as you still have the gasket space.
But you've got nothing to loose by trying to clean with wire wool. Good chance it will clean up.
Rammie2000
Member #: 10190
belgium
Ill try it with wire wool. Only point of concern then is the right hand side down corner of the block. Looks a bit deep to me between the pushrod hole and that water way.
Rammie2000
Member #: 10190
belgium
Skotchbride is wire wool right?
jonny f
Member #: 9894
Dorking
No.
Scotch brite doesn't create such a mess.
for you *wink*
http://bfy.tw/3gPU
Edited by jonny f on 12th Jan, 2016.
Rammie2000
Member #: 10190
belgium
A yeah okey... moms cleaning sponges. Should have googled it. Thought it was the overseas saying for wire wool or steel wool as we cal it pixwel. Grts
PhilR
Member #: 10034
Birmingham
I was actually thinking about Scotchbrite soap pads (which are wire wool) and for some reason thought that's what Jonny meant too... although I agree, it does make sense to start with the green pads.
Either way Rammie, you're going to clean and rebuild it, yes? *wink*
Edited by PhilR on 12th Jan, 2016.
slater
Member #: 1291
Try emery roll wrapped round a nice flat file.
Rammie2000
Member #: 10190
belgium
Emery roll... another one for google there. And yes thats the plan. The story is that the short block was build by keith calver ( if i Wright it right) yet gona pul the pistons out and start from there...
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
LOL *smiley*
If i have more toys than you when i die, I WIN
I'd try some 800 wet and dry around a block lubricated with some light oil first.
Block looks like it'll clean up, head looks like it'll need a skim.
If you do need to skim the block, the pistons sticking up a few thou won't be an issue.
What will said, less mess and keeps stuff flat all over
Rammie2000
Member #: 10190
belgium
well i went to look for some sponges at moms house and once home went straight at it. head cleaned up nice but that block will need a skim for sure. to me it looks like the head can take up quite some cc's so compression want be an issue. the only doubt now is do i have the block honed or not. pistons sit nice and snug now and dont want to much space between bore and piston.
Rammie2000
Member #: 10190
belgium
or would you guys go at it with that 800 grid first.
PhilR
Member #: 10034
Birmingham
800grit on the block? No chance. That needs a skim. Head looks fine though.
Rammie2000
Member #: 10190
belgium
gona get it tested on leaks while they are ad it
jonny f
Member #: 9894
Dorking
Photos have gone?
Rammie2000
Member #: 10190
belgium
ow crap. yes i cleaned up my photobucket somewhat. just a second ill fix it
jonny f
Member #: 9894
Dorking
Skim on the block head looks spot on!
