Home > Help Needed / General Tech Chat > Gt17 down pipe
ian2000t
Member #: 2764
Halesowen
What does everyone use for downpipes on a GT17 build?
Is a Saab downpipe any good as a base, or do you buy a GT17 flange and just DIY?
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats.
Matty is your man mate.
fixitphil2
Member #: 10945
scarborough/ northyorkshire
got mine from matty and his manifold.fit straight onto 2"mini play exhaust too
Down pipes are not difficult to do if you can weld at home.
ian2000t
Member #: 2764
Halesowen
Cool OK, is the Saab downpipe any use, or just get the flange and 90 degree and DIY ?
ian2000t
Member #: 2764
Halesowen
Double post..
Edited by ian2000t on 17th Jan, 2016.
We used a Saab dp with an extra bend in it. Fitted well.
ian2000t
Member #: 2764
Halesowen
Thanks, which Saab downpipe do you start with?
I found the 9-5 1999 onwards uses GT1752 - is that the best one to start with?
I bought a 2 1/4" pipe with a flared end
http://www.ebay.co.uk/itm/Exhaust-Connecto...Spo3LM2tcVOYFow
Then I clamped it with somethiong like this http://www.ebay.co.uk/itm/Exhaust-Flange-M...a8AAOxyyvRSMdlx
You need to check the bolt spacing.
Just needs a tight 90 deg bend etc after that. sorted
