| Home > General Chat > Random Q - Changing from Auto to Manual? | |||||||
Site Admin 6303 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
18th Jan, 2016 at 10:46:13am
Hey all,
18th Jan, 2016 at 10:51:39am
http://www.minimania.com/Mini_Automatic_to...sic_Information If something is worth doing, it's worth doing half of. |
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
18th Jan, 2016 at 02:57:20pm
Manual subby or the blocks to make up the difference in frames, pedal box or just pedal, gear stick n rods.. think ya need different driveshafts too? On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
18th Jan, 2016 at 05:55:20pm
That thing that johns put on about sums it up. If you make the spacers from 10mm plate chances are they may be too thick, I've converted 3 cars and they all differed, they may just need a Nats taking off one or both. Despite what the write up says about the top engine steady, fit an adjustable one so you can get the engine when you want, the carb twatted the bulkhead on the first two I did with the auto top steady. Also there's no provision for the front lower engine steady so you'll need one off a manual ,set your engine with the top one and it's a simple bracket needed welding onto the subframe. Other minor annoyance is the gear shift will go straight in but if you use the factory gaitor the holes are miles too big for the std fixings, I seem to remember using riv nuts or even rubber nutserts and 4mm bolts. I seem to remember some tomfoolery with the reverse light switch too but nothing too hard. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
18th Jan, 2016 at 05:57:05pm
Provided it's a pot joint auto driveshafts are the same as manual iirc On 18th Oct, 2013 apbellamy said:
18th Jan, 2016 at 07:49:44pm
the driveshafts are no different to any Manual Min, whether pot joint or hardy spicer/ crucifix types.
Edited by Sprocket on 18th Jan, 2016. On 26th Oct, 2004 TurboDave16v said:
18th Jan, 2016 at 07:49:59pm
So the easy method would be to just build up a 'complete' front subby with driveshafts, manual engine/box and shifter mech, and fit that along with a clutch pedal and cylinders? |
18th Jan, 2016 at 07:54:25pm
I wouldn't say replacing the whole subframe assembly was easier than just drilling a couple of holes and making a couple of spacers.
18th Jan, 2016 at 08:02:00pm
It's just there are lot of nice autos about atm - and if the aim is to change the engine for a turbo anyway, I was wondering if it mattered what the original car was. :) |
18th Jan, 2016 at 08:33:18pm
18th Jan, 2016 at 08:51:20pm
something like that |
18th Jan, 2016 at 09:06:12pm
