| Home > Help Needed / General Tech Chat > O/T suggestions on a friends austin 1100 | |||||||
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
21st Jan, 2016 at 05:49:59pm
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
21st Jan, 2016 at 06:07:57pm
I'm sure there was an issue with boosting the 1100 but will leave that for someone else.
21st Jan, 2016 at 06:10:55pm
All I'd do is swap the final drive or something a touch longer. Allegros for example used a 3.9 final drive as standard to suit the 13" wheels and high profile tyres. At a guess the 1100 may be similar. A swap to say a 3.4 would give an Austin 1100 a bit more legs, the long stroke 1098 has enough guts to pull it. Be a shame to really mess with it too much.
21st Jan, 2016 at 06:21:49pm
Completely agree about not messing with it too much and using the original engine but if you see it from my friends point of view for a minute you may agree.. or atleast see his point? (I can now see where hes coming from)
21st Jan, 2016 at 06:29:41pm
One day i ill get around to building a decent ado16!
21st Jan, 2016 at 06:54:51pm
Don't the cranks snap in these with to much power?? |
21st Jan, 2016 at 10:35:41pm
No. With too many rpm as its a long stroke. In the 13's at last!.. Just |
21st Jan, 2016 at 11:54:09pm
Its a combination if the bore and stroke, its a very under square engine. The rod angle and piston speed reduce the rpm potential significantly. Similar reason why diesel engines dont like high revs. On 26th Oct, 2004 TurboDave16v said:
22nd Jan, 2016 at 07:52:11am
What about a gaycharger like Andy's. It's a realy nice installation that has a period look.
22nd Jan, 2016 at 10:49:15am
On 22nd Jan, 2016 wil_h said:
What about a gaycharger like Andy's. It's a realy nice installation that has a period look. Whack that on running 5 or 6psi, use a spacer to lower the CR, happy days. You'll get something a bit better than a breathed on 1275. Superchargers are not gay unless you fit out the engine with yellow hose On 26th Oct, 2004 TurboDave16v said:
22nd Jan, 2016 at 01:23:23pm
Lol. Bottom hose is now black Col, does that male it bisexual? On 11th Feb, 2015 robert said:
22nd Jan, 2016 at 01:45:18pm
It makes your car a ladyboy witha black dong!
On 22nd Jan, 2016 apbellamy said:
Lol. Bottom hose is now black Col, does that male it bisexual? Edited by wil_h on 22nd Jan, 2016. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd Jan, 2016 at 02:11:56pm
I'd just stick a breathed on 1275 with a 3.44 in it and keep the 1100. If something is worth doing, it's worth doing half of. |
22nd Jan, 2016 at 02:27:46pm
Lot simpler to superchage it than change the engine, if a bit more expensive perhaps - and it is then easily reversible too. |
22nd Jan, 2016 at 07:00:06pm
