Home > Introduce Yourself > New member
Mjjenkins01
Member #: 11306
Rhondda
Hi names matthew from south wales.
Baught my mini around 2 years ago and have been restoring it since.
Recently installed a metro turbo engine but in having problems with it cutting out when i build the revs any advice?
Hello
Sounds like the carb is not plumbed up correctly to allow the fuel pressure to rise as boost is made.
Welcome to tm
Mjjenkins01
Member #: 11306
Rhondda
On 28th Jan, 2016 wil_h said:
Hello
I followed the photos to blumb it in ate they correct?
Shauna
Member #: 10424
Swansea boyo!
Where are you? I can pop over and have a look for you one night if your close enough!
Yo
D4VE
Member #: 10749
lowestoft suffolk
Welcome!
Nothing gets past Dave lol
How do.
Yes the photos are correct. Check the balance pipe has no leaks.
Another quick check is to make sure that the gasket between the plenum and carb is correct.
There is a hole on the right hand side of the main bore (close to the threaded holes). This needs a corresponding hole in the gasket. It's common for people to block it off. This results in the floatbowl not pressurising as boost rises.
Also worth checking is that the restricter is fitted in the plenum.
Mjjenkins01
Member #: 11306
Rhondda
Im in tonyrefail
Mjjenkins01
Member #: 11306
Rhondda
I havent got a clue about this stuff mate it wiuld be great uf you had some photos?
A warm welcome!
jonny f
Member #: 9894
Dorking
Welcome along!
Post up a project thread :)
hazpalmer
Member #: 9038
Carlisle, Cumbria
How do!
e5tus
Member #: 10128
Dorset
Welcome!
I can grab a photo later, simple fix with a blade.
Here you go.
Don't block extra hole on left hand side
Mjjenkins01
Member #: 11306
Rhondda
Cheers i will check 😃
On 29th Jan, 2016 wil_h said:
Here you go.
Mjjenkins01
Member #: 11306
Rhondda
I just checked and the hole is not blocked is there anything else it could be?
search for 't piece trick'
Also, are you using the metro turbo dizzy with the ignition module on the side? These need a decent 12v supply. If your mini is a ballast resistance model, you may be feeding the module at 9v, they don't like this and do strange things. Also, a dying module can also do strange things. Worth investigating/changing.
Other than that, you'll need to start looking at the carb. Make sure it's all working fine and has the right needle. A wideband lambda gauge can really help here.
Mjjenkins01
Member #: 11306
Rhondda
I beleave i solved it the bike on the carb that os supposed to be blocked wasnt air tite
