| Home > Beginners Tech > A Guide To Uploading Pictures Using the Basic Upload Tool | |||||||
30th Jan, 2016 at 06:54:07pm
If you want to upload pictures or other supported files in your topic or post quickly, to share with others on the forum, you can use the basic upload tool located at the bottom of the 'Post Topic' or 'Post Reply window' by clicking on the link 'Add Attachments' in the bottom left of the page, and the 'Browse' button appears. (see picture 1)
Edited by Sprocket on 31st Jan, 2016. On 26th Oct, 2004 TurboDave16v said:
30th Jan, 2016 at 09:58:27pm
On 30th Jan, 2016 Sprocket said:
Note that you can only upload documents with the extension .jpg .gif .bmp .zip .pdf and be aware that these extensions are case sensitive. For example, a file DC000001.JPG with an upper case extension (.JPG) will refuse to upload. If your files use the upper case extensions, you need to edit the document extension, replacing it with lower case before you can upload them. i will just add, in most cases you can simply rename the file "DC000001.JPG" and type the .jpg in lower case e.g "DC000001.jpg" once the name is saved the picture will upload im not sure if its just my phone or the site but i cannot upload a 16mp image, i have to drop the size by atleast half Yes i moved to the darkside |
Site Admin 6301 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
30th Jan, 2016 at 10:01:38pm
Great guide for a pants UI I developed over 10 years ago! |
30th Jan, 2016 at 11:11:04pm
Uploads are no longer case sensitive so file extensions can be whatever case, and the file size limit has been increased.
31st Jan, 2016 at 01:18:03pm
On 30th Jan, 2016 AlexB said:
Uploads are no longer case sensitive so file extensions can be whatever case, and the file size limit has been increased. :) Cool cheers :) hopefully can upload from the phone now :) Does that include the non forum section too? I tend to use that alot Edited by Brett on 31st Jan, 2016. Yes i moved to the darkside |
31st Jan, 2016 at 01:56:29pm
Filesize yes, but haven't changed the code so if it was finicky then it still will be. |
31st Jan, 2016 at 02:02:34pm
Cool cheers Yes i moved to the darkside |
31st Jan, 2016 at 10:30:10pm
I'll edit the first post to reflect the fix to remove any confusion. On 26th Oct, 2004 TurboDave16v said:
![]() 1751 Posts Member #: 10190 Post Whore belgium |
16th May, 2018 at 10:09:43pm
every time i try this i get a box with you have to put in a title or something while i just was replying to my own post
Edited by Rammie2000 on 16th May, 2018. you can do anything if you set your mind to it...
