Home > Help Needed / General Tech Chat > What is this and do I need it? Primary gear.
Ok,
Looking to change the primary gear when I put my engine back together.
The primary gear I am replacing has a sort of metal ring around it where it butts up to the crank oil seal.
What is it and does it matter that it isn't on my replacement primary?
Picture:-
Edited by John on 2nd Feb, 2016.
oil flinger ring, stopps too much oil getting on the seal....
just prise it off the old one and tap it on.
Ta! That was my thinking but thought I ought to check with someone smarter than I, unfortunately the dog was sleeping.
LOL!!!
That primary gear looks odd anyway. Was there an early 1275 primary gear?
I thought the same Colin, the taper of the teeth looks like its been done aftermarket
Maybe it's been munching at something and that's why the ring is missing.
One is 29 tooth the other is 30 tooth eco primary, both A+
Edit, my bad
The eco gearset has a double groove. It looks line the primary gear only had a single groove to match the input gear. The standard primary gear had no groove.
Edited by Sprocket on 2nd Feb, 2016.
In the box yes, not the drop gears.
Single groove is standard 29tooth
