Home > General Chat > Ford leads?
Shauna
Member #: 10424
Swansea boyo!
Where do you guys buy your leads for megajolt from? The set I have now are absolutely ridiculous because they are so long from Euro. Poor guys running a bit rough so new plugs and leads tonight to see if that helps as I've checked all the other culprits! The type I have atm DON'T (Carl being a durr and telling me false information!) clips on to the coil pack btw!
Edited by Shauna on 15th Feb, 2016.
Iirc its ford ka for long leads and ford fiesta for short ones
What coilpack do you have? Do they have the clip on leads or normal?
I think for mine i got a long set and put new ends on so i could get them the correct length
I got these for the metro; they are long enough to take the leads over to the inner wing where the coil pack is mounted and not far off the same distance as the mini
http://www.ebay.co.uk/itm/331066036641?_tr...K%3AMEBIDX%3AIT
I also bought plugs from the same source; don't know about you guys but I used to pay £3.50 for 4 years back.
http://www.ebay.co.uk/itm/331263204286
Shauna
Member #: 10424
Swansea boyo!
I've got a fiesta coil pack now as it was playing up before so I changed it. Even the shortest one of my set are too long really!
Does anyone else have a fiesta coil pack?
Shauna
Member #: 10424
Swansea boyo!
These look similar to the length I had befor. I'm not kidding, the longest one I have on there atm is about 4ft long!
if you look at the description, it gives you lengths of the leads; may be worth a bit of a search on their site to identify the shorter set
I went to Halfords and got two sets of leads cheep with a card, then had the 4 short ones out of them, easy fix
Shauna
Member #: 10424
Swansea boyo!
That type fitted the old coil pack I had, Carls confused the hell out of me saying one thing then another! I've attached an image for the type I've got now! They are between 76cm and 93cm accommodation to the Euro website haha! I don't really need them to be any longer than 45cm
Shauna
Member #: 10424
Swansea boyo!
I did say about doing that but he's said they don't sell them any more :/
beejay
Member #: 10785
Derby
Pretty sure my coil pack came from a Focus, with a set of leads that clipped on properly. Trimmed the spark plug end to length then used new terminals and covers from here:
http://www.vehicle-wiring-products.eu/sect...on-ht-terminals
move the coil pack to the rear parcel shelf ?
oli79
Member #: 8480
For an exceptionally clever bloke you do have some daft suggestions, all she needs to do is leave the coil pack and wrap the leads round the crank pulley to take up the slack surely?
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Shauna
Member #: 10424
Swansea boyo!
Always two! Haha. As I'm changing them anyway I'm just wondering if there's actually shorter ones I can buy without having to cut and put new ends on them. Might just live with them and then buy a KA coil pack when the engine comes out for a tidy up!
Midas
Member #: 7555
Why not just buy the ends and shorten the leads. Yours will be second Gen at a guess.
http://trigger-wheels.com/store/contents/en-uk/d9.html#p17
Jay#2
Member #: 648
Northern Ireland (ex AUS)
That's what I did and was easy enough, plus I was able to put 90 degree ends on rather than the straight Ford ends.
On 7th Nov, 2008 Nic said:
naeJ
m
Shauna
Member #: 10424
Swansea boyo!
Yeah it looks like that's what I'll have to do if I can't get shorter ones off the shelve. I did buy some ends before but they arrived and looked horrible so I never bothered doing it. Carl found me some better looking ends earlier so I've ordered some to just cut new leads on to. Fingers crossed he's running as normal after changing them!
