Home > Help Needed / General Tech Chat > is it T2 or T25?
lanxter
Member #: 396
sheffield/rotherham
well here are some pics of the turbo ive aquired, still unsure if its a T2 or a T25 on the actual turbo itself it says:
B.C.1 M10 A/R.48 then garret and in a circle after garret says 92.
because of the positioning and wear of the label on it i cant fully read the numbers but the 1's ive managed to get are this:
27700853265
here are some piccys ive taken sorry bout the poor quality.
so can any1 tell me if this is a T2 or T25?
also any ideas what it is off?
thanx
mark
speed is the best rush i have ever had!!!
add me lanxter@hotmail.com
Dangerous
Member #: 417
I reckon t2 as my t25 has 5 bolts on the bottom picture
lanxter
Member #: 396
sheffield/rotherham
also the part that connets to the manifold its self says A.R .41
You shouldn't concern yourself with weither it's a T2 or T25, instead it is the suitability for your engine that will determine this...
So the turbine is a 0.41 AR - well that's good at least.
What was it off?
mikemph
Member #: 449
Oxford
The T25's I have seen have got 5 bolt outlet flanges so I guess its not one of them. Just for reference, some IHI turbos (punto turbo) very similar outlet but not exactly, but look to have a slightly smaller exhaust and compressor housings, I have no tech info on them so just by eye.
lanxter
Member #: 396
sheffield/rotherham
not sure what its off, a friend bought it originally for his car but found it was too small. and went and bought a pulsar engine instead.
the guy he bought it from was not sure what it was off.
SumpNut
Member #: 28
It looks very different from my T25.
My turbo is different within the exhaust housing (my wastegate isnt separated like that)
My compressor housing is different - as i cannot put silicone tube strait onto it, i have had to have another pipe made up.
AR wise it will be fine, just fit it and stop worrying!
dan
Member #: 93
might be a one of the newer gt-series of turbo's
measure the turbine inlet and compare to this to see if its a t-series
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=3274
Edited by dan on 9th Sep, 2005.
lanxter
Member #: 396
sheffield/rotherham
wasnt worrying mate i just need to know so i can get my mate to knock flanges up lol
I've seen severl T2_ turbines like that... I think Jim has seen one aswell.
yes my exhaust housing is like that on my t2, would love to know what its from so I can source a gasket
Edited by Jimster on 9th Sep, 2005.
lanxter
Member #: 396
sheffield/rotherham
yep thats the 1, well the flanges etc are no longer a problem as my friends agreed to make me a custom 1 so thats not too bad.
thanx for your help lads
is that a copy of max power I spotted on the floor??
lanxter
Member #: 396
sheffield/rotherham
no mate, its redline only bought it cos a few of my friends are in the back with there cars.
the front cover happens to b a 206 with a cossworth turbo lump in around 300bhp.
lanxter
Member #: 396
sheffield/rotherham
oh and its 4wd :)
