Home > Help Needed / General Tech Chat > Dizzy
joe
Member #: 9546
Hi all
I know there are alot of threads about dizzys and megajolt but i can not find what i am looking for.
I am collecting all parts for my turbo build at the moment. So would like to know of i carnt find a original turbo dizzy is there a alternative dizzy to go for that is upto the job.
Thankyou in advance
imo the single best think you can do for the A series is bin the dizzy and fit some sort of distributor less ignition such as Megajolt ( mjlj )
Edited by Brett on 19th Feb, 2016.
slater
Member #: 1291
Suffolk / Birmingham
You could modify a standard dizzy so that it doesn't advance (fix the weights) but its a right bodge. Megajolt is the way to go for a budget build.
There is no alternative from the BL range of dizzies.
You could but a 123 dizzy that has a turbo map. Or use a standard dizzy and use an Aldon amythist or similar.
tadge44
Member #: 2500
Buckinghamshire
But it is definitely worth saving up and using Megajolt, as slater says.
Yes, absolutely.
