Home > General Chat > Plenum choice
kezzboycat
Member #: 10371
leicestershire
What best choice of plenum are people using
Stainless?
Or home made ?
Or standard/modified
Mate has a very nice stainless one but not to sure where he bought it
Depending On your intercooler piping Route and do you run a servo? The stainless ones are made by nicks mate haywell nick can be found on here forum moderator.
kezzboycat
Member #: 10371
leicestershire
Will be no servo no clutch cylinders in the original place so plent of room
The 2 main ones you will see are as benross says a 'nic plenum' and a standard/ modified one
Price wise probably about the same nowadays
The nic plenum inlet pipe is from the right
The standard/mofified one the inlet is usually from the left
jonny f
Member #: 9894
Dorking
When i emailed Hywell he said he was very busy, pointed me in Matts direction.
Matt made mine to what i wanted, although i do regret not asking for the diameter of the inlet to be the same as the IC.
Its one of the last things you should sort in my opinion when the engines in and you know exactly where the IC will be.
Matt as in manifold matt?
Didnt realise matty made plenums too.. excellent
longy
Member #: 2727
Bicester
http://www.fusionfabs.co.uk/turbo-mini-plenum-chamber
1972 998 TURBO SLEEPER
I was going to suggest Fusion Fabrications too
jonny f
Member #: 9894
Dorking
Yea fusion fab :).
Does them in alloy.
Very happy with mine. Only thing to note is he doesn't separate the mounting bolt holes like on my hywell one they were tubular. So I put some copper washers under them.
monsterob
Member #: 11029
Crewe
I have a nic one sat on the shelf unfitted with heat shield its looking like im not going to use
If you want one and hes busy .........
Outside the box
Mattys a good lad and is very! Good at fabrication and welding. . . . . . So its Matty plenumbs now! Great!
