Home > 998cc > 998 turbo
Ola
Member #: 683
Sweden
Hi . Have a budget turbo project, Its a 998 A, 998 A+ top, Hiff 44 turbo carb, VW golf Diesel turbo,
My question is i think the Hif44 is to big (from a 1275) , what needel profile should i begin fouling around with ..*smiley*.
Going to update my photo album soon ...
Regards from Sweden
(Mod Edit - Moved to 998 turbo section)
Edited by Tom Fenton on 7th Nov, 2005.
Doodmeister
Member #: 149
Alberta, Canada
.....*smiley*
Edited by Doodmeister on 11th Sep, 2005.
Dangerous
Member #: 417
Intercooler ???
Dr. jinG
Member #: 368
Roseville, CA (USA)
I believe he means that he intends on using the turbo unit from a VW Golf. From what I've read, that's not a good idea as the seals in diesels are incompatible... True, or myth?
1967 Cooper 's' Turbo build @ www.drjing.com
Ola
Member #: 683
Sweden
incompatible with what , fuel ? never heard of what.. intercooler maybe... cheers
yes, apparently diesel turbo's are made from different materials to petrol one's and therefore arent suitable for use on a petrol car.
who knows it may be a myth but im sure someone had proof the material was defo different
Ola
Member #: 683
Sweden
Okej, I never heard about that. I will check it up.... But so what, on a tight budget anything goes . *smiley*
cheers / ola
if its free or virtually free then go for it *smiley* just didnt want to see someone wasting a lot of cash on something that may not work *smiley*
nutter driver
Member #: 47
Not very sunny swanage
diesel turbos work fine on petrol engines, they may not last as long, (although cant comment on that with any accuracy) but they work absolutely fine, and are usually designed to boost a lot higer safely than petrol turbos!
They'll be fine... Unless you're going for really high boost / EGT's
Re the carb, keep it simple. Stick with the HIF44.
Ola
Member #: 683
Sweden
Thanks for all coments.. will stick with the Golf turbo and see how it works.*tongue*
Is it same needel typ in Hiff44 turbo and non turbo Hiff / HS carbs ?
BDD is the needel what?s in it now, to rich for my little 998 maybe??
